Bunch of random pics of cutters
9:40 PM
Dolmar 496 (aka. Oregon Vanguard) , 3/8" , chisel , factory ground NEW
P1080133.JPG P1080133-00.jpg P1080135-00.jpg P1080136-00.jpg P1080137-01.jpg
9:40 PM
Dolmar 099 (aka. Oregon LPX , thank You @huskihl ) , 3/8" , chisel , factory ground NEW
P1080064.JPG P1080064-00.jpg P1080065-00.jpg P1080066-00.jpg P1080067-01.jpg
9:40 PM
No Name (I received it in a care package from the US) , 3/8" , chisel , factory ground NEW
P1080084.JPG P1080084-00.jpg P1080085-00.jpg P1080086-00.jpg P1080087-01.jpg
Ugly protruding rivet heads, I see them catching fibers and creating drag.
9:40 PM
Oregon 091 , 3/8" LowProfile , semi chisel , factory ground , made some test cuts
P1080101.JPG P1080101-00.jpg P1080102-00.jpg P1080103-00.jpg P1080104-01.jpg
Much less hook that the Dolmar 092 above!
Moparmyway
Its just a saw
3:40 PM
In a meeting
I could use some help getting this to self feed on 42” 3120.
To me, the wheel never touched the corner of the tooth, and I agree with @Wilhelm, you went low into the gullet, going too low into the gullet hurts performance, makes the chain more grabby and robs power to do so
davidwyby
Rural desert logging
12:40 PM
Extreme Southeast CA
I have some Stihl RM that seems to cut well and hold up well, I will try to emulate those angles as well. Also the Stihl guide for angles.
I probably should have put my .404 full chis skip loop on, but the wood was very dirty. You can see on the stump I had chip clearing problems.
@deye223 @rogue60
9:40 PM
@deye223 @rogue60
I got Stihl RM from Sondre, I think I made some test cuts - I do not recall whether I liked it or not.
I have some small to medium diameter but muddy logs to buck at my neighbors.
I am uncertain whether I want to bother try semi chisel or just whip out the Stihl RD3 carbide loop. :confused:
I am seriously leaning toward CARBIDE! ;)
My free time is too limited and valuable right now.
3:40 PM
9:40 PM
Different cutters anyone?
Here it comes, stay tuned!
My speciality. :)
9:40 PM
Free hand ground HSS-Co 17.0mm drill bit.
In the chainsaw chain world this would be considered a mean full chisel square grind.
Shallow 140ish° angle, cross cut center, extreme "shoulder" back cut - makes one mean drill bit You don't want to use drilling free hand!
3:40 PM
@deye223 @rogue60
RM should cut pretty well. The side radius is so small it’s not far from full chisel
9:40 PM
Same drill bit "detuned" to be less aggressive.
Kinda like a semi chisel/square ground chainsaw chain hybrid.
I picked this mod up from WiDia solid carbide drill bits I had the pleasure to test run, IIRC they advertise this grind like "4 dimensional" or "4 corner" cutting edge - I'd have to look it up to be certain.
