Bunch of random pics of cutters
Jason628
8:32 AM
Washington
I started a long thread on the cheap, ‘Harbor Freight style’ grinders on A.S., due to a challenge. Bottom line: cheap is cheap. Did not like the wheels on most of them either.
Here is a link, if interested:
https://www.arboristsite.com/threads/hf-chain-grinder-thread.268303/
If you know what you are try achieve, you might be able to improve a dull chain, but they are not my first choice.
Philbert
Ya... I'm not a fan. You take off way more material than necessary with those grinders. I like my chains to last.
2-4 swipes with a round file is usually enough to get it sharp again unless you messed the chain up.
davidwyby
Rural desert logging
8:32 AM
Extreme Southeast CA
It takes more skill and mechanical ability to make a cheap tool work than a good one….and eyesight. That was my point in making this thread. So people can see what cutters should look like and what effect different angles have.
Jason628
8:32 AM
Washington
I'm not that good at sharpening chains so, it is helpful to have some good pictures of what the cutters are supposed to look like. It is a lot easier to start out with a brand new chain that is round ground and sharpen as need be as it is easier to keep the right angle and Gullet depth VS trying to straighten out a chain someone grinded or filed all wonky. I have plenty more of those chains to mess with. Honestly by the time I get it back to where it will cut decent again I probably would be better off just getting a new chain for $25 haha but, it's good practice.
fossil
11:32 AM
Ontario, Canada
Have any of you guys tried filing a standard 3/8 chain with a 5/32 file?
Some friends say it cuts really well. I haven't tried it myself.
5:32 PM
That's 4.0mm, for 3/8" Picco/Low Profile
You would most likely get a very sensitive cutting edge, and filing with that thin file is tedious as it flexes and bends.
My Stihl Rapid Duro 3 loop had a tiny little C-shape factory ground into the carbide insert, IIRC 3.2mm.
It cut great and held up a year of bucking firewood logs of various species.
Try it and report back! ;)
fossil
11:32 AM
Ontario, Canada
Better known as the little C ?
Yes, I think that's what they called it.
Good point on the flexing. I'll stick the file in a Granberg 106B. That should help.
Jason628
8:32 AM
Washington
Get a husky roller guide if you don’t have one yet @Jason628
I'm doing pretty good with a file guide so far. I got one of those little hand crank things I'm going to try out and see if I like it. Will probably get the husky roller one too. Trying to find something that works well and is pretty easy to use so dad will stop destroying his stihl chains hahaha
davidwyby
8:32 AM
The husky is a good trainer because you can see what’s happening. Check it out on YouTube.
Jason628
8:32 AM
Washington
I bought this Stihl chain from EBay, it originally came from a rental department store.
I resharpened it by hand , maybe a little hooky.View attachment 352513 View attachment 352514
Would hooky be okay for softer woods? That's pretty much what my cutters look like on the chain I just finished. I mostly cut pine and fir. Tamarack is probably the hardest wood we cut. A dead standing tamarack is pretty hard to find anymore though...
Maintenance Chief
11:32 AM
South Carolina
Personally, yes its fine gor me. Even with hard wood for alittle bit . It just requires a shorter sharpening interval.
Timjus
6:32 PM
Finland
out of the box c85 grind this time.
picture.php
picture.php
picture.php
5:32 PM
I made the "Big-C" version of that X-Cut cutter the other day.
I have to try it though.
I also have a new X-Cut in .325", but it will remain new for a while. I need to spend all the slow semi chisel .325" I have so I don't have to look at them no more.
Ground deep into the gullet, then round filed with the file positioned lower than recommended.
You can see where the file sat in the second picture.
This was merely play, I like my chains with a big C and the file positioned higher.
