Bunch of random pics of cutters
pbillyi69
4:26 AM
USA
cool. i cant wait to hear how well this works. have you tried this before?
davidwyby
Rural desert logging
4:26 AM
Extreme Southeast CA
I did but I dunno if it helped, too short of a bar and not in a felling situ
It was pretty fast tho 😁
12:26 PM
I keep posting pictures of my 36"/115DL "hillbilly skip with a twist" but it doesn't seem to get noticed.
Take a full comp loop, grind off the top plate on every third cutter, do not touch the side plate, sharpen as You would a regular full comp loop.
You got a semi-scratcher chain.
Bucks and noodles hardwoods great, less clogging than with a un-modded full comp when the bars full length is utilized.
ZERO
Simple Life
12:26 PM
Woods & Mountains
Nice work.
That side beak will eat through hard wood like :):)
JimG.
7:26 AM
NorthCountry
I decided to finally try square chain. Rocked it pretty good on my 4th cut so I get to learn how to sharpen.
Down the rabbit hole I go.
How's this look?
Squareground3691
7:26 AM
New England
How's this look?
Practice and Patience is ur friend, ur blunt , witch is good in the wood ur cutting, just needs some fine tuning on the underside of ur cutter angles , angles vary with wood species, the sharper angle for softer wood and blunter angles for tougher wood ,try to match up top plate and side plate angles with a tangent line on the underside of tooth in corner we’re they both meet, 5 degrees forward lean is idea ,for side plate , cut ur gullet back to bottom of cutter with round file , Ur on your way and stay out of dirty wood, or ur good day will turn into a bad one real quick, Lol
Squish9
10:26 PM
Australia
Great advice. It takes a lot of practice to be able to do this and it's like learning to sharpen all over again.
I have now tried 5 different files to find the shape I like and have tried so many different ways of filing. My preference is for the Pferd 1250 TKD files.
Compared to the Vallorbe style of this file they have a slightly smaller overall diameter but larger flat sections for the side plate. They also have a less aggressive cut than the Vallorbes.
I file inside to out. Tried both ways but I'm more consistent this way. I also mark a 45 degree line on the bar as a reference line. I saw this in a Vallorbe video and find it helps give me a basic guide. I don't need it for small touch ups but if I'm converting round to square or have done some serious damage it helps me.
davidwyby
4:26 AM
Reminds me of an idea I had for square filing or at least learning. Start with already square chain and file one edge at a time. Don't have to keep track of so many angles at once.
12:26 PM
Trying to avoid this:
Std full comp :
Sweeper cowboy skip
Seems to help a little but cut slower. I think the cutters I hacked back are dragging.
Your "sweeper" cutters still have a top plate that will bite.
My hillbilly skip version only features a side plate functioning as a scratcher.
Try converting Your mod to mine.
I'd love to know whether it makes a positive or negative performance change.
Squareground3691
7:26 AM
New England
Won’t your side plate angle be wrong with a true square file?
I just posted it for the above question, if anyone makes a square file looks like a machine file not actual chain file, I use a double bevel myself,
