Bunch of random pics of cutters
8:51 AM
Husqvarna X-Cut C85 , 56DL/15" going through a 20" Turkey Oak log
Started with an over cut and just pulled her around.
Makes a very narrow kerf, but still works fine for a k095 bar (a D009 bar would most likely get pinched).
Woodslasher
Teh debil
11:51 PM
Commiefornia
Damn it, I know better than this! :mad:
It was too late once I felt it.
This chain WAS so sharp it went through cherry like a hot knife through butter, till it suddenly didn't.
I am angry at myself, no need to ad salt to the wound.
Gonna grind that mess out now.
This is my 84DL Oregon full skip! 😢
View attachment 410834View attachment 410835View attachment 410836
This is pretty similar to what the chain on my loaner 562 looks like every time I get it back. That being said, I grind chains for the person who is usually the culprit and Carlton chain is invincible. An Oregon chain can get fubared like that in 1hr of cutting, Stihl will do a little better in a day, Carlton can do days of that and still throw decent chips. The Carlton chains I are also hard enough they break all the teeth off of my files whether they are new Stihl, used Oregon, or anything in between.
pbillyi69
11:51 PM
USA
didnt blount buy oregon and carlton. i have been through the carlton factory before. it was quite an operation back then.
8:51 AM
Brand new Stihl flat file, tried setting rakers on my MMWS6100 Vanguard loop.
Most of the LH rakers were so hard they just ruined the file.
I ended up grinding the rakers.
This is my Husqvarna flat file after de-burring a lot of milled 12.9 grade bolt steel.
I need a couple new flat files!
Ketchup
Epoxy member
12:51 AM
Colorado
View attachment 411101 View attachment 411102
View attachment 411103 View attachment 411104
I’ve been putting cutting gel on my files. Definitely helps.
I just recently started prepping my files with cutting gel. It does seem to help.
Maintenance Chief
2:51 AM
South Carolina
Squish9
4:51 PM
Australia
I had this with a roll of GB branded chain about 5 years ago. Every depth gauge had a super hard bubble of chrome on top that destroyed the file. The guys I bought the chain from gave my money back and though the roll out.
JimG.
2:51 AM
NorthCountry
Specifically what product have you been using with good results?
I have never tried it but I seem to recall hearing that leaving dull files in a pan of acid for a while would revive them some.
Junk Meister
1:51 AM
Nebraska
My neighbor saw mill used a gel-stick on his carbide teeth before grinding/sharpening the 60" circle blade. He said it kept the edge cool and hypothetically kept the diamond dust down.
Ketchup
Epoxy member
12:51 AM
Colorado
Ain't sayin it’s the best, just what I had. Got it in an auction. It helps keep a bond between the cutter and the material from happening and reduces loading. If your files are too soft it won’t help.
Ketchup
Epoxy member
12:51 AM
Colorado
I tried the acid. Maybe I did it wrong but it didn’t bring the files back to anything I wanted to use.
8:51 AM
Could you be over heating the chain while grinding?
It is possible that I got the rakers hot grinding/modding them.
Although I doubt it.
I used to file all my chains and I remember that Oregon Vanguard chains always had irregular hard cutters and rakers.
I never noticed such inconsistency on the LGX/LPX chains.
