Woodslasher
Teh debil
- 9:25 PM
- Mar 18, 2021
- Commiefornia
Dang, that thing looks clean! Nice job!
I just ordered so vol 40 developer to try on a Stihl tank and starter cover, thanks for posting that.I went ahead a ordered the Holzfforma case splitter for about $50 shipped. I know the bearing will stay in the case when using that one vs the MX case splitter I have. The bearing staying in the case is a lot easier to deal with vs stuck on the crank.
Now that I know the "retro bright" whitening technique works and doesn't damage the type of plastic husky used for these, I have the nicer white top prepared. It's coated in the "40 volume" developer cream, plastic wrapped and I placed it outside this morning in the sun. The cling wrap is to keep it from drying out. If that stuff dries out on the plastic, it can possibly mess up the finish.
I don't want this thing perfect, I just wanted it a bit less yellow and chalky oxidized. Later this evening I will show the results and the muffler rust removal results as well.
I restored this one. It was shot -- no spark and no chain brake. Somehow it had good compression and it runs today:
I got mine form HLSupply. It's an import and was much less expensive than that. It works really well.Hey what do you think about that aftermarket chain brake / side cover? I have a friend that wants me to build him a 61, but his is missing the side cover/ chain brake. Probably my only option is aftermarket for that....I see one OEM on ebay but they want like 130 bucks for it, yea right.
Obviously your understanding of economics is limited if you think "brandon" has anything to do with current conditions. Are you familiar with supply/demand concept? Early 2020, demand cratered and supply was through the roof. Now its the opposite, demand is through the roof and manufacturers cant keep up, so prices increase. Econ 101. Not to mention the FACT that its your fukkin hero's fed chairmans policy thats led to a lot of this. And all the stupid fukkin tarriffs that said glorious leader imposed. And thats just scratching the surface. Stick to postin pics of ur 036 youve posted 1000 times.In all, I doubt if I spent $60 shipped for both, but that was four years ago before Brandon's inflation kicked in
I looks good, am a novice at these piston ports. I wonder if sacrifice some compression for more exhaust duration would be better. I have built some compression kings the cut like duds, super snappy Duds! Lol your saw isn’t a dud, just saying.Larger 224a carb installed on the 61 build. This wood is quite a bit larger than the prior test but that's ok, I ran both saws again. I also touched up the chain before running the saws. I'm happy with the results! Getting closer to my goal for the 61 build.
I have been studying porting. (The Ironhorse, Tinman's Saws, and J&S Chainsaws on Youtube have been really helpful since they do a lot of these series of saws).
I hesitate to give any advice because of my lack of experience. My advice would be to post your numbers and ask for some advice, I'm sure some of the experienced porters will help you out.@Ronie - I was going to start pretty conservative but I need to see where the timing as at first. The plan was to clean and open up the lower transfers, not touch the upper transfers, raise exhaust roof 2 degrees, and lower intake 2 degrees.
