Master Bud II
- 10:37 PM
- Feb 16, 2019
- Northern Ca.
@Stump Shot - That was extremely helpful! Thank you so much for taking the time to write that all out for me.
Question - 180 degrees of Intake timing sounds like a bunch, did I miss read that? I kinda had in my head to shoot for 78 for intake (156 duration), which is really close to what you also mentioned.
Also, what about the lower transfers? Should I smooth out, blend in that ledge at the bottom?
Thanks! @Stump Shot
I'm about to go lay my marks out and do some grinding.
I forgot to ask what the "winter filter" is on these saws! The nylon mesh ones instead of the felt?
I use a bit of sealer on those gasketsHere is the carb side. It's factory size. It looks a little uneven, but there's so little room to correct because of the gasket and the impulse line ridge. Everything is port matched though so as uneven as it looks, it's smooth with the intake and gasket
Not too much.
You could try running a 266 style filter holder and filter.![]()
I have been wanting to for at least a month! Lol.
My search for the later grey/black top or a 266 top has come up with nada so far. The two screw style wont fit under these early white tops unfortunately. If you know of any around (grey/black 61 top or 266 top)....help a guy out?!
