- 8:04 PM
- Apr 28, 2016
- Croatia
Thought it had something to do with reduced drag when rounding the bar nose in a cut?I think it aids "releasing the wood chip sooner" thusly reducing drag.
But I could be wrong in my thinking.
It is something a "racer" has to address!
It is a "race chain thing"!Thought it had something to do with reduced drag when rounding the bar nose in a cut?
In any event, it shortens the top plate, so you need to replace your chains more frequently!
Philbert
So, then, it also shaves some weight off the cutters?It is a "race chain thing"!
Technically yes!So, then, it also shaves some weight off the cutters?
Philbert
Can’t figure out how to explain itPlease explain.
The cutters heel kicks the cutting edge "out of the wood" as it turns around the bar nose thusly reducing bite of the following cutter and causing "chatter" due to uneven bite.Can’t figure out how to explain it
I hope You are stocking up on that!![]()
THE DUKE'S PROFESSIONAL HARD CHROME 3-PACK FULL-CHISEL CHAINSAW CHAIN
[PROFESSIONAL] Professional style chain, with hardened, blued and chrome plated cutters. [HARD CHROME] Hard chrome is electroplated onto the cutter. This chrome creates a harder cutter with better durability and wear resistance. [STAYS SHARP] Chain stays sharper, longer as a result of the chrome...www.sawsalvage.co
It's good stuff for a reasonable price!@Duke Thieroff how is that stuff? I might get some 84s and respin
I'll have some rolls here after about 30-60 daysIt's good stuff for a reasonable price!
Let’s try to rememberI'll have some rolls here after about 30-60 days
Nice clean stamping, no "safety junk" either - that is a really good looking chain!
