Brewz Saw Builds
Brewz
4:06 PM
Hunter Valley - Australia
I got a mate to take a pic of under the cover of a HT 12 off his 088
It appears to have an additional jet for the L idle feed (top left).
The HT 5 on my 084 doesnt have the 3rd port to feed the L curcuit so it must draw from the same port as the H
Perhaps the improvement they made to the later HT's?
I may actually put the HT 12 on my 084 and cut off the limiter tabs to shh how it goes as well.
Brewz
4:06 PM
I got the 1308 coil fitted up
Put the HT 5 back on and pulled the cord.
Its a different saw with the 1308
Its as easy to start as my 044 now. I have blood blisters on my hand from the mongrel limited coil biting me.
The 1308's retarded start got it started quick and easy, and it kicked up with a nice slow idle that built and settled to smooth and nice.
It was on dark and my neighbors have little kids so I have a no saws after dark rule.
I gave it a quick rev with the H screw all the way in and it definitely ran much faster than it did with the limited coil.
Will check tunability and RPM tomorrow arvo and will also give the HT 12 a run, see what it can do. I like the idea of a separate jet for the idle circuit on the 12
Brewz
4:06 PM
HT 12 has a seperate jet to supply the idle circuit and the H brass jet is bigger at 1.04mm
I have removed the limiter tabs and will try it on the 084 later on
Brewz
4:06 PM
Here is some more findings
I just fitted the HT 12 from an 088 and the saw loves it.
Tunes easy, better idle stability and will lean out to 14000 rpm but not screaming lean like the HT 5 that bumped 15000 on the tachometer.
I am happy with that cause it's happy running at 13000 rpm and I have no desire to push it to destruction
One thing I discovered during the carb swap is that the later HT carbs with the plastic limiter tab arrangement around the L and H screws has a throttle connecting bar with a bit more of a dog leg in it to get around the plastic thing.
The HT 12 will be staying on it
Brewz
4:06 PM
It needs to go lean enough to work on a 70cc saw.
Ahhhh
My guess (it's a guess) is that the brass jet that says .94 on the HT 5 and 1.04 on the HT 12 is the fixed jet limiter because the 5 will lean our more than the 12 that has a larger jet.
Try filling the jet with some solder and see what it does.
If you need more fuel you can always drill it out starting small to get what you need.
If I couldn't adjust this saw enough that was what I planned to do but it's just my hunch
Red97
1:06 AM
MI
That jet looks like the same one
Some of the hda carbs. 196 I think.
Probably is smaller being off a 50cc saw. then open it to where needed.?
Brewz
4:06 PM
Just be careful with high rpm on these saws. They can break cranks [emoji6]
The rod can't take it.
It's made from a coat hanger.
So what do you think would be a safe max rpm to tune the saw to?
I sure wouldn't run it at 15000. That was just a figure it will go to if leaned right out.
jmssaws
Banneded
12:06 AM
I got one to do soon as the piston gets here
Don't know what carb is on it,forgot to look
