Ketchup
Epoxy member
- 1:42 AM
- Mar 12, 2018
- Colorado
Not sure I could recommend that because the 550 XP already has been criticized for running a bit too warm. The carb is mounted too close to the cylinder and that sets up vapor lock that then leads to hot start troubles. Upgrading that engine to the 562 might make it worse. Just MHO.
Now, of course, you could argue that a larger cc engine might allow it to run cooler and solve some overheating problems. Always a possibility, but both the bore and the stroke are larger on the 562, so it won't be easy.
I looked into it. It’s pretty close to impossible.
Somewhat related, 572 and 592 both have a 39mm stroke. Could be something there.
