All things Hybrid
thedude74
Bonafide & Stuff !!!
9:46 PM
Alaska
thedude74
9:46 PM
Alaska
Woodslasher's 056/066 hybrid build
Ketchup
Epoxy member
9:46 PM
Colorado
Some important crumbs in here. @Shane¹
Ketchup
Epoxy member
9:46 PM
Colorado
thedude74
9:46 PM
Alaska
Looks like it kinda petered out. Scarrs idea of the 2100 crank is interesting. Topped with a 395 big bore that's a 105.6 cc 288xp. These hybrids, strokers and hybrid/strokers intrigue me.
davidwyby
Rural desert logging
8:46 PM
Extreme Southeast CA
I’m gonna give it a look once some parts get here
Ketchup
Epoxy member
9:46 PM
Colorado
Word around the log pile is that 2100 cranks are prone to big end failure.
Deets’s 43mm stroke 090 idea is pretty cool.
thedude74
9:46 PM
Alaska
I hadn't heard this before.😐 Just got a new 2100 P&C for the 285.
288/395…so husky can keep up with a 661 😆
My neighbor just seized his bosses 661....Even a Husky rancher can whoop it now. 🤣
thedude74
9:46 PM
Alaska
I’ve got a few photos but I didn’t do a very good job documenting so far. Plenty more to do. If it doesn’t crater I’ll try to do a writeup.
Any further developments on the 361 stroker hybrid? At one point someone on eBay was selling a crank bearing(or seal?) bushing for the 440 crank swap.
While I had a Echo 4910 apart I got a 49mm 361 big bore cylinder out and stared at them for a few minutes. If not mistaken the both have an 11mm piston pin. But to be honest I never checked since the 361 is side fed .....echo is bottom fed and mounting flange is a mile off.
Ketchup
Epoxy member
9:46 PM
Colorado
I looked hard at 361 on a 4910. Unfortunately the base pattern is way off. IIRC the deck height is a problem as well. 357/359 can be squeezed in, 365special might even fit with enough effort. There are several other side fed cylinders that might work as well. When you’re down-stroking like that you want a jug off a saw with a high deck. You need to drop the jug, so adding a base plate isn’t practical. Luckily 4910 is 33mm stroke, so you only have 1mm to compensate for.
Ketchup
Epoxy member
9:46 PM
Colorado
This needs to be here.
thedude74
9:46 PM
Alaska
What did you think of that 4910/357 hybrid? Was it stronger than a ported 4910?
The 365, if possible looks like excellent candidate. Bottom fed 48mm closed quad netting 59.72cc
Ketchup
Epoxy member
9:46 PM
Colorado
The hybrid is much stronger than my ported 4910. There are difficulties with the transfer flares on the 365S. A husky 268 may be a better fit.
Wood Doctor
Edwin
10:46 PM
Omaha, Nebraska
Anybody got a 550 to 562 conversion thread? Considering having a try.
Not sure I could recommend that because the 550 XP already has been criticized for running a bit too warm. The carb is mounted too close to the cylinder and that sets up vapor lock that then leads to hot start troubles. Upgrading that engine to the 562 might make it worse. Just MHO.
Now, of course, you could argue that a larger cc engine might allow it to run cooler and solve some overheating problems. Always a possibility, but both the bore and the stroke are larger on the 562, so it won't be easy.
