All things Hybrid
thedude74
Bonafide & Stuff !!!
10:35 AM
Alaska
Any more 50cc saws with 60+cc cylinders swapped in? How about a bored and stroked 70+cc on a 50cc chassis? 🤔
thedude74
10:35 AM
Alaska
More Dyno Joe hybrids!
Echo/Stihl
Hulpio
DIY addict
7:35 PM
Finland
Generally any 34mm stroke cylinders on a 32mm stroke frame?
Did I read about Husqvarna 55 with 61 top?
thedude74
10:35 AM
Alaska
Do you know if the 288 and 272 share the same bolt patterns? I have a 272 tore down on my bench, might look into this upgrade before putting it back together!
I might have one (288) apart in a couple hours. Looking for cylinder bolt pattern numbers?##
hacskaroly
2100 Fanclub Member
9:35 AM
Northern Idaho, Ehh
Yes, doing quick eyeball match on pictures of the two on the internet, they look really close, however, I did see a forum post that said they are not a match (or they could be matched with some machine work). Looks like bore size may be different (272 = 52mm w/34 mm stroke, 288 = 54 mm w/38 mm stroke) maybe?.
