592XP info and a surprise
redlight066
6:25 PM
Taylors SC
It has a few common parts from the 390xp. Clutch, drum, and recoil. Not sure if the oil pump is a direct swap I didn’t get that far. Big end of the rod looked a little beefier.
the air filter let a few fines by in the tank of fuel we put through it. It may need a light film of grease around the lip. Ala HD2. Saw performed very well. This is a hot start saw. It does get heat soaked after several minutes. Fast idle start IS necessary. That’s about all I got.
redlight066
6:25 PM
Taylors SC
Last thing. Saw went back with the rep. We should have a loaner/demo in a week or two. Honestly for a brand hammer new saw out of the box it’s a strong saw. Timing is advanced to the edge. We ran it with a 28” bar and all I heard was popcorn. I did make an attempt to hook it up to the diagnostic tool and it couldn’t recognize it.
srcarr52
6:25 PM
Iowa City
jacob j.
Only the weird
3:25 PM
Coastal Oregon
Interested in why you think that? 661’s have em and are really liked by lots here on the coast.
The 661 I rebuilt didn't have crank stuffers, and it was a fairly late model (production code December, 2019).
It did have the funny-looking thing for directing the charge up into the cylinder, like the 461.
6:25 PM
I was thinking the flange that goes up inside the piston, my bad.
Crank stuffers are on the crank counter weights and it effectively is a “full circle crank”. Not having them shifts the powerband a little lower in rpm where a 90cc saw needs to be. Especially milling or with a long bar in hardwood.
6:25 PM
I could be wrong, but in theory stuffers should always be better right? Port timing can be adjusted to provide the power curve you want.
Definitely. The smaller the case, the more charge gets pushed up. Move the power band down with the port heights
CR888
8:25 AM
Australia
Mmmmm them transfers are big and need feeding, having a bit more case volume could be good for torque. What a sexy saw. Finally Tsumura have taken light weight bars seriously and made one thats actually light. It's a real bonus not having to spend a couple of hundred on a bar when buying a new saw. Stihl got their light bars right, looks like Husky has too. I hope that Purdy Tsumura bar will be sold in Stihl mount. I wonder whether the boss will include the 592 in Huskies latest 20% off sale.
