- 6:31 AM
- May 24, 2019
- WV/NC
I think I'm "decently" tuned now at least for the options available to me.
Two days ago was the first trip I got to take to and from the WV hills grossing 26-27k. It was probably the best trip I've ever had. Before on most of the hills I would pull down to 25mph and be grabbing gears non stop. But this time I never dropped below 45mph. Most of the 45mph hills were because there was another truck in front of me or if it was a long hill I had to run the splitter to raise rpm to cool it down. Dropping road speed in the process. On very long pulls it would climb slowly to 1250/1300. So nothing really terrifying and I probably could keep it up there but I'd rather not have this rig break down any time soon lol. This also leads me to believe the old AD injectors were junked even though they would pass the buzz test.
My current build specs.
Orion - single shot tunes from PHP running level 5 "250hp" setting
160/0 injectors from Full Force diesel
Kc300X stage 1 63/68/.83
Homemade 4" Downpipe, 5" Donaldson muffler, 4" factory stack
Bellowed uppipes
910 valve springs
ARP head studs
Dual Super Duty pumps - Removed mechanical lift pump
DIY Regulated return with fuel bowl delete (Set at 65-67 PSI)
Hiflow Banjo bolts
CNC Fab Hpop Lines
Riffraff crossover
Some Ebay Plenums
My father's house finally sold so we have to start getting stuff out. We started with his car.
Also I don't have any boost leaks or uppipe leaks. Once I get my exhaust pressure gauge hooked up I'm thinking of cranking down on the waste gate some.
Besides that do you know of any other things I could do. I thought about water/methanol, but everyone is like "you don't need that with good tuning".
I didn't even have to drive this trip. So I got to get some photos and videos.
P.s. please ignore my duct tape gauges . I have a piece of kydex I need to bend for them.
I've also decided next year when I do the transmission I'm also going to chop the rear off frame and lower the bed as well so I can do 5th wheels and make the bumper pull hitch closer to axle.
The only issues I found yesterday morning was the front fuel filter was seeping. I tightened it down. The regulator mount broke. So I'll make that out of some mild steel to hold up to vibration or maybe a rubber mount. Then there some oil on valley probably from the HPOP. I don't know if I should try and hunt down the leak or just replace it all together.
I burned 67/68 gallons of fuel for 461miles. Really the mountains I don't think did it as much as the flat land. So a transmission with an overdrive would be nice.
Bellowed uppipes
910 valve springs
ARP head studs
Hiflow Banjo bolts
CNC Fab Hpop Lines
Riffraff crossover
Some Ebay Plenums
