- 2:56 PM
- Feb 5, 2016
- Here & Now
TriLink for play chain?View attachment 326721Round play chain. Never seen wood sadly. I'll try to get picks of the cutters tomorrow.View attachment 326722Round to square hand filed. Little low in the corner.
That is semi chisel.View attachment 326856 Approximate angles
Interesting. I checked that loop next to another assumed it was chipper. You’re likely correct.That is semi chisel.
This is .404 chipper.View attachment 326883 View attachment 326884 View attachment 326885
You can see the completely rounded profile of the side plate.
Clip the heal makes for smoother bore cutting or so I've been told.TriLink for play chain?
Give it a try, let us know how it works.
What does clipping the heel do?
Better chip clearance, better chip flow?
I have a couple .404" loops with cutters like that, they cut sooooo sloooow.That is semi chisel.
I always thought of them being "round tooth".![]()
And it is in .050" gauge.That's old chipper chain.
It was basically the first design that was after scratcher chain, so an improvement.And it is in .050" gauge.
Not a very impressive chain in terms of cutting performance even on a short bar.![]()
