Year end build
Maintenance Chief
12:33 PM
South Carolina
I think the carburetor is holding you back on Horsepower.
Just my opinion ( so take it for what it is), could be the intake is too smooth also, as in your getting droplets instead of vapor in the fuel charge.
Got any regular 272s data from the dyno?
Red97
12:33 PM
MI
I got 3 or 4 that need dyno’d…
Send em in...
Could be the carb for sure. I bet it would like more. I'll have to see what can swap in sometime.
Never had a 272 on the dyno.
Maintenance Chief
12:33 PM
South Carolina
Send em in...
I mean honestly looking at the curves ,that looks exactly like the type of saw I like to use ,wide band of power a plenty of torque.
I absolutely hate peeky saws that constantly bog and hunt for the magical power rpm .
pbillyi69
9:33 AM
USA
i would very much like to know what a ported 357 puts up for numbers. more so i wonder what the one that scott ported for me puts down.
12:33 PM
Awesome thread. @Red97, you do super cool stuff.
Do you think an OEM cylinder would make a difference?
I wonder how much affect the 359 case has on performance. Would more case volume be helpful?
Chainsaw Jim extended the transfer lowers on his down to the case feeds. That had to add a lot of case volume.
I’m working on a 359/272 hybrid and was considering going the other way: filling the 359 case feeds with epoxy. Not really because of volume, just because they create a dead space. But it does reduce case volume. Do you think that will be a mistake?
I think it’s a mistake.
Tight case-More Vacuum/Compression. So it’s gonna pull more charge in and spit more back. There’s no reed valve.
It’s like when guys make full circle cranks. To the best of my knowledge they reduce intake duration and powercurve gets shifted up in the rpm range.
I think he needs more carb too, but Joe does monster 590/52mm 046 Hybrids that do great with the stock modded 590 carb (unless I am mistaken).
I also hate AM jugs. There is a finesse in the OEM transfer tunnels that’s not always readily apparent.
Red97
12:33 PM
MI
Joe,
I am wondering about case volume mismatch. Have you considered adding some JB weld to the intake floor? Easily reversible and you have that awesome Dyno.
My bet is that the 272 cylinder can’t fill. Very tight cases need less intake duration.
Hmm less intake and more case compression? Guess it would be easy to try. Fill it up to 70* and see how it responds.
I do believe it has some sort of carb issue. I'll have to try the one from my 357 to see if any change.
