460/660/390xp/395xp hybrid?
Rich Fife
Sally slap my ass
12:36 PM
Central New York
Well, this is a little different build than all of my previous builds... I have a bunch of parts kicking around, some parts I forgot about.
I'm starting with an 046 case, a 390xp crank, a 660 big bore cylinder and either a 395xp piston... I won't know the exact route until I get the case together. Below are some of the parts as well as the progress thus far.
Rich Fife
Sally slap my ass
12:36 PM
Central New York
Well, I decided to pull the 390 crank apart and do it the tedious way.
Once apart, I faced the ends of the pin to match the length of the 046 pin. I decided to 'polish' the pin...
Rich Fife
Sally slap my ass
12:36 PM
Central New York
Now that the crank halves were separated, I needed to find a way to be able to turn them in a lathe. I figured the easiest way would be to make a modified lathe dog.
Rich Fife
Sally slap my ass
12:36 PM
Central New York
The finish wasn't the best but it's smooth and spot-on size.
Rich Fife
Sally slap my ass
12:36 PM
Central New York
well within spec.-- what is the spec? .0015 TIR? Where do you find the specs / tollerances? Nice job so far!
Well within my spec... the shaft was at .0002" of runout. Which, if the shaft was originally turned between centers, it should be concentric or easily Well within .00025" from one machine setup to the next... (if everything is correct)... I'll have to do a video of the runout.
This is a perfect way to check to see how well the manufacturer did when making a crank half... or checking the alignment of the tail stock etc.
Only downside so far is the shafts werent as hard as I would've liked if i was going to use it for a replacement... however, I do like how soft (mid to high 40s on the c-scale) it is for turning/modifying in a lathe. If the shafts were induction hardened and then ground to size/spec... this would've been a Nice replacement crank for cheap. The casting was actually really clean, uniformly smooth.
Rich Fife
Sally slap my ass
12:36 PM
Central New York
I had to use the old South Bend and cut the LH threads for the clutch. These threads are supposed to be M12x1.0... my lead screw doesn't have the correct pitch so I used 26tpi. Some might say that's wrong... and I'll agree but, it works. These threads are only 5/16" in length so the thread difference is very minimal and they work in a pinch.
Rich Fife
Sally slap my ass
12:36 PM
Central New York
The fitment of the flywheel and the taper on the shaft is uniformed. The clutch and accessories fit perfectly.
I'll have to match the counter weight lengths and then it'll be a matter of putting the crank halves together and dialing them in.
After that is complete, I'll have to assemble the saw and do a mock up for ignition timing.
