Year end build
slackinoff
12:35 AM
usa
@Red97 - Wow! That's an awesome result. I was glad to read you kept going on this one.
Ketchup
Epoxy member
11:35 PM
Colorado
Found a wee bit more. About as I expected, the fingers seem to add a "hit" up top. But should make a dandy 60cc firewooder.
That’s a huge improvement! The torque curve is especially impressive.
I suffered a major setback on mine. I set it up for port work last night. Stock numbers are 76/98/112. I doubt I can drop those transfers enough. Very unhappy with the Hyway jug.
Red97
1:35 AM
MI
Hmmm.....
What piston/setup did you use?
Ketchup
Epoxy member
11:35 PM
Colorado
Hmmm.....
064 piston. 0.040” out of the band and 0.080” off the crown put me at .025” with 2 gaskets. If I keep going with this jug I’ll take more out of the band and try a 038 magnum piston.
It has other problems though. The uppers have a lousy exit angle and the plating is flaky AF.
I’m not happy with my workmanship either. I went too fast.
Red97
1:35 AM
MI
Seems the 038 piston is the way to go with these. I would happily shave another .020 off the piston starting over on this one.
I feel ya. Mine is rather rough around the edges and piles of "modified" junk left in the wake... trying to stay focused and making projects like these happen I tend to run through lots of parts trying to find the "just right" pieces.
I have had the best luck with the bottom of the barrel 20$ eBay white box kits.
farminkarman
I like the red & black ones
12:35 AM
Neenah Wisconsin
Just curious, why do you think the 038 mag piston is the best?
Maintenance Chief
1:35 AM
South Carolina
I'm gonna set at .019 squish for my 625/272 build, I like the torque numbers yours were sitting at.
I got a used oem p/c from Bob when he had his retirement sale.
Red97
1:35 AM
MI
About the shortest pin to crown height with Windows. And keeping ok skirt width. I believe the 046 is the same height as the 38
I took .060 from the band and .010 off the piston and still had to run a gasket. Dolmar 7900 piston may save some machine work too bit rather limited skirt width. These shorter strokes need to be able to have wide ports.
farminkarman
12:35 AM
Neenah Wisconsin
I see what you mean.
460 piston has coated skirts, and 038 is bare.3267F8D8-6B81-40AD-BC41-79E597365ED5.jpegB3DDEC26-B5C1-4D9F-89A5-5179B3DCE735.jpeg
Ketchup
Epoxy member
11:35 PM
Colorado
