- 9:13 AM
- Sep 4, 2018
- Central Kansas
Same here.
Speaking of crazy. Looking for a input here. I was running my 592 today no load on it about quarter throttle of a half throttle. And it was acting like it was running out of fuel sputtering. Not like the carburetors look in the tune itself just like a gas issue any thoughts.It's complete craziness here in CA
They need to be run wide open. Anything at part throttle for an extended time messes with themSpeaking of crazy. Looking for a input here. I was running my 592 today no load on it about quarter throttle of a half throttle. And it was acting like it was running out of fuel sputtering. Not like the carburetors look in the tune itself just like a gas issue any thoughts.
Good to know I appreciate that and thank you I was not sure if it was me or watt.They need to be run wide open. Anything at part throttle for an extended time messes with them
More information and your thoughts being the first time using it??@Mastermind done gone and run the 592 today...24" with a real snotty chain, banging off the limiter. Nice job buds
I used it prior to drop and buck a 30" rock maple, but I ran a couple tanks thru it bucking firewood last night. Smooth, very strong, pretty good on fuel, oils well for my purposes.More information and your thoughts being the first time using it??
Love mine, same first thoughts and very ergonomically made.I used it prior to drop and buck a 30" rock maple, but I ran a couple tanks thru it bucking firewood last night. Smooth, very strong, pretty good on fuel, oils well for my purposes.
Starts nicely, I will say that. 3 pulls and that puppy is running from a cold start
I suppose another alternative is that the main nozzle check valve could be leaking. I believe that will potentially push air up underneath the diaphragm and lean it out at idle. Am I thinking correctly? @srcarr52 @Mastermind
Had the L screw backed out 4 turns until it got floppy, still lean.In theory that could happen but I've never seen an engine with enough demand at idle to create the pressure needed to force air into the bowl.
Does it idle if you give it a tiny bit of throttle? I could just need more fuel at idle or more air after the port work.
Purge bubble was sucking air. And the goofy shaped hose from the carb to the bubble slid on and off too easily. I unhooked the purge bubble and it died instantly. Plugged both hoses and it idled fine. Found a used bubble and S shaped hose from a 562 and put them on. The S shaped hose actually fits better anyway. Been idling for 15 minutes now perfectly
It was….for about 7 mfing hours nowNice find. That could’ve been a head scratcher.
Persistence pays off in the f-in end .It was….for about 7 mfing hours now
Nice find good fixHad the L screw backed out 4 turns until it got floppy, still lean.
Purge bubble was sucking air. And the goofy shaped hose from the carb to the bubble slid on and off too easily. I unhooked the purge bubble and it died instantly. Plugged both hoses and it idled fine. Found a used bubble and S shaped hose from a 562 and put them on. The S shaped hose actually fits better anyway. Been idling for 15 minutes now perfectly.
Bottom line, if you have idling issues, plug the purge line coming from the carb and try it. It won’t idle correctly if there’s the slightest possibility of air getting into that line
Nice work Kev. You’re a lot smarter than you look! I understand the idea behind the purge bubble but this is why I’ve never been a fan. Just one more thing to break.Had the L screw backed out 4 turns until it got floppy, still lean.
