Stihl Hexa file and sawchain
11:14 PM
I keep a 36” on a saw, but don’t really “need” it..
I’m at a loss. I don’t know what length bar to put on what size saw anymore. I think I will just start mounting them up at random, regardless of the cc and then go cut a log that fits that bar
Hedgerow
10:14 PM
None of that *s-word matters..
Make power and let the end user figure it out,.
They can just change the sprocket to suit..
davidwyby
Rural desert logging
8:14 PM
Extreme Southeast CA
I’ll make it worse. I’m reading about cutting hazardous trees and spring poles n stuff. I’m thinking hmm, maybe a 42” bar super light weight, 3/8” LP on a ported 60cc so I don’t have to be close when it lets go…:D
5:14 AM
It's like:
1) I use a 20" B&C on my 90+cc saws for up to 36" diameter logs, I can lower the chains rakers and utilize a 12pin sprocket
2) I use a 28" B&C on my 50cc and under saws for the reach
Crazy world eh?! :p
davidwyby
8:14 PM
No..
But he seems to be getting enough fuel...
And that’s a good thing.
I had the carb apart to get pics n measurements n stuff for @Benwa to make his carb adjustable and I didn’t actually tune it when I put it back together, was just messing around with that short bar. I’m sure my neighbors wouldn’t have wanted to listen to me fiddle with trying to tune the H on that thing…I was at the back fence and my son was doing yard work in the front and said he could hear it echoing up and down the street. :D
davidwyby
8:14 PM
@Wilhelm I run 20” 12 pins on 120cc for 9” wood, see above :D
36” wood I run 42”…I don’t “walk around”…unless it’s over 42”…
different strokes for different folks. More than one way to skin a cat… I can see running short bar and biggish PH for hard stuff and I can see running longer bar and skip on a ported smaller saw for soft stuff…I’ve done both to some extent….more towards the long side, need to try more short.
11:14 PM
Spring poles suck. I wish I had a pole saw for them
3browns
7:14 PM
Fishhook, Alaska
The Asplundh crew is clearing power lines down the way and I noticed a guy up in a bucket the other day with a longggggggg pole saw that looked to me like it had a separate remote power source that had an encased drive that looked flexible
He was going through wrist sized stuff like he was on the ground with a 50cc saw
My Google Fu sucks cause I can't find any reference to one or even a picture
But man, one slick pole saw
3browns
7:14 PM
Fishhook, Alaska
like this but looked beefier and stuffs
Wonkydonkey
Plastic member
4:14 AM
Sussex, UK.
Why use a small bar on a 660 saw like that? I use a 50cc saw for wood that size, and it cuts just as fast...
yeh I absolutely agree, that ft 660 should have ripped through that log a lot quicker.
Shame we didn’t get to see the chips
anyhow he does have a few other vids on the hexa file as well as comparing other different saws,
also a new homeowner saw stihl ms162 where he compares it to a 171 , so he must be a stihl field tester
Edit, this is painful to watch :rolleyes:
P.M.P.
Stiff Member
11:14 PM
Michigan
Sure go crazy put a 36" Stihl bar on a 70cc husky and stuffs. Maybe make a video for us window lickers
