Johnmn
- 4:51 PM
- Feb 18, 2016
- Minnesota
http://opeforum.com/threads/mikes-chainvises.4322/I would like to see pics of your vise
Thanks for the link
I have chain vises for sale 130.00 shipped to lower 48.Thanks for the link
Is there a website?
How much are they?
Follow along http://opeforum.com/threads/mikes-chainvises.4322/
I also have bar adapters for D025 to D009 (large husky to 12mm stihl)
I have Dolmar to D025 mount (6400-7910 to 12mm stihl)
I have D009 to 14mm stihl
I have Do25 to echo 590 600 620
Feel free to email with questions homelite410@gmail.com
You're probably related...a hour
Have not seen that style before!
Philbert
I'm have a problem holding the drivers on my Tecomec auto-grab grinder. Seems like the vice pinch point is too far behind or the clamp is not spreading the load enough. I fixed the hydros so they work well. Oregon's new vice has a different design. Same hydro cylinder in the same location.Mike made it for the purpose of square filing I believe.
Does a good job of grabbing the drivers on either side of the cutter. "No chatter"
Yes.Has anyone seen this video?
Is this the famous tree monkey?
Did his T shirt give it away?Yes.
It is tree monkey.
Uuuuggh....... maybeDid his T shirt give it away?
That’s a nice lookin toof Mr. Pecker.I decide to give the ATOP jig a try. As a complete noob to square filing, I am pretty impressed. Learning curve for it was relatively easy.
First tooth .325 LPX
Took quite awhile to convert it from round to square but I needed the practice anyway.
Cross cut with depth gauges set to around .030 on the MOFO 026 in spruce. I'm pretty happy, but time will tell in hard wood.
Looks like softwood angles from that pic. For hardwood you’d need to have a fuzz more downward angle on the file and roll it into the tooth a bit. Doesn’t take very much
Looks like crap, you suck, GFY...I decide to give the ATOP jig a try. As a complete noob to square filing, I am pretty impressed. Learning curve for it was relatively easy.
