Not Sold On Square Filing
Johnmn
1:06 PM
Minnesota
Woodpecker
Sassy Madam
2:06 PM
2:06 PM
I look at this square file thing like a straight razor to a chisel and an exe .Certainly the square is sharper and to a point should cut faster but it will not hold that edge as long as other alternatives .On the other hand you can't shave with a cold chisel but you can cut steel . Try that with a Case XX straight razor .Apples and oranges .
Lightning Performance
2:06 PM
East of Philly
Mike made it for the purpose of square filing I believe.
Does a good job of grabbing the drivers on either side of the cutter. "No chatter"
I'm have a problem holding the drivers on my Tecomec auto-grab grinder. Seems like the vice pinch point is too far behind or the clamp is not spreading the load enough. I fixed the hydros so they work well. Oregon's new vice has a different design. Same hydro cylinder in the same location.
That square vice looks nice. Gives me ideas.
Woodpecker
Sassy Madam
2:06 PM
I decide to give the ATOP jig a try. As a complete noob to square filing, I am pretty impressed. Learning curve for it was relatively easy.
First tooth .325 LPX
Took quite awhile to convert it from round to square but I needed the practice anyway.
Cross cut with depth gauges set to around .030 on the MOFO 026 in spruce. I'm pretty happy, but time will tell in hard wood.
Deets066
AKA Deetsey
2:06 PM
That’s a nice lookin toof Mr. Pecker.
Looks like softwood angles from that pic. For hardwood you’d need to have a fuzz more downward angle on the file and roll it into the tooth a bit. Doesn’t take very much
Woodpecker
Sassy Madam
2:06 PM
Thanks Deeter that makes sense. I thought the down angle looked a bit acute.
Maybe the learning curve was easier for me having used and seen a lot of good square, but I think the thing would be pretty user friendly for the average round filer.
beaglebriar
The Peanut Gallery
2:06 PM
Warren Center, PA
Looks like crap, you suck, GFY...
Homemade
2:06 PM
Wisconsin
Looks good considering the atop is designed for 3/8 chain.
