The SR 71 airframe was made from ti because of its strength and the entire plane saw some very very extreme heat.
EDIT:
When an SR-71 Blackbird is at Mach 3, how hot is the airframe? A: At speeds of Mach 3 (3 times the speed of sound) the SR- 71 Blackbird's airframe temperature can range from 315-480 degrees Celcius (600-900 degrees Farenheit), depending on its altitude.
Not sure it could even be measured? It takes energy to compress the intake charge. That energy comes from the liquid fuel stored an the tank and vaporized in the carb etc...So lower compression will give one slightly better fuel consumption vs a fully ported high compression saw?
It sure makes the stacks crackle on a funny car though, don't it? Too much is just enough!
Very impressive, is this a complete departure from what you've done in the past on these saws or are you tweaking a previous formula? I appreciate your time and effort, keep em coming...Having a hard time keeping high tune free spooling. Switched carb, drilled jet, raised metering lever. A new line and filter is on its way.
New. Never tried the 272 piston in one. Only 2nd Hybrid I’ve ever built.Very impressive, is this a complete departure from what you've done in the past on these saws or are you tweaking a previous formula? I appreciate your time and effort, keep em coming...
Still practicing my Hindi
I have that exact same problem with my 10mm 044 that has an old Zama. hold it wide open and if it is tuned above 13500 it four strokes nice and then starts to creap into higher rpm's. If it is at 13500 it holds steady. The Zama on my 12mm tunes fine. I just assumed it was the carb.New. Never tried the 272 piston in one. Only 2nd Hybrid I’ve ever built.
The chamber was done for the owner, to keep geometry but lower compression for starting. It may be the cause of the tuning issue, I’m not sure.
Having issues holding high tune piss revving while trying to set it out of wood. Discussed with many pros last night, noones quite sure. So far I’ve drilled the main jet, increased metering lever height (too much), and swapped carbs.
Next it’s getting a new fuel line/filter and tank vent. Can’t test till next weekend, no time.
It’s making impressive power. I’m gonna pull the jug to inspect soon. I’ll replace the pin with a cut down stock steel pin at that time.
Piston still perfect. 2 tanks in.
I’ve got a bunch of carbs here. Weather permitting, I plan on a lot of fuel system play.I have that exact same problem with my 10mm 044 that has an old Zama. hold it wide open and if it is tuned above 13500 it four strokes nice and then starts to creap into higher rpm's. If it is at 13500 it holds steady. The Zama on my 12mm tunes fine. I just assumed it was the carb.
Thanks, I look forward to the result's of next weekend's testing, look's to be a strong runner, especially considering the manner in which it authoritatively pulled the full comp 36"! I love experimentation, trying something outside ones comfort zone, sometimes yields impressive "new" ideas and/or methods. Not qualified to comment technically, but appreciate your effort and sharing...New. Never tried the 272 piston in one. Only 2nd Hybrid I’ve ever built.
