Jack’s Husky Infused 440/460 Hybrid
2:33 AM
Looks like a good runner Al, Congrats!!!
I have another 460 jug with broken fins if you want it, but I think the jug looks ugly (factory ports).
Jeff, generally high compression will increase fuel efficiency, but it depends on lots of other factors. In 1969 my Dad purchased a LTD with a 390 High Compression 2 bbl. The factory was trying to improve fuel efficiency with the higher compression. I think that was the only year they made it.
2:33 AM
I have to disagree, I have had more problems with the 044 style vents, and they seem to be NLA. I purchased some AM 029 tank vents, and they seem to work well on an 044!!! Just have to be a little creative when you install them.
The originals are often rotted and completely non functional.
Chainsaw Jim
Con Artist LLC
11:33 PM
Springfield Oregon
You're disagreeing with my experience with them? Lol
2:33 AM
I’ll be checking the vent for sure. It’s possible, as the saw tended to do it more after I let it warm up. I thought it was heat that changed it, but it coulda been negative tank pressure.
Judging by the way this saw drinks fuel, it’s certainly possible it’s the culprit.
I’m gonna change line and filter first. If it’s the same, I’ll try vent.
Or I’ll pop the vent first, and see if it’s instantly cured. That sounds easier.
angelo c
Coal Member
2:33 AM
been thinking about how to back pressure or flow test a fuel filter so as to eliminate that in diagnostics. ( me being a diagnostics guy and all... :) ).... kindda like an early nerve conduction .. :)
2:33 AM
Not sure how the stihl fuel filters are but the husky ones are very easy to tell when there getting bad. The new filters are pure white. When they get bad there browish yellow.
angelo c
Coal Member
2:33 AM
well its pretty obvious the Stihl filters are superior to the icky husky filters....Im surprised the screws even stay in the husky filter :pesas::pesas::applaudit::coleman::risas3:
2:33 AM
all joking aside...are there filters that flow better ?
and how would we know ?
seems we spend an enormous amount of energy to maximize fuel flow only to guess on...fuel flow
any fluid dynamics engineers out there with any suggestions...or ramblings.
Tach the saw on the same tune with several filters. Whatever flows the most will have the most rpm.
Chainsaw Jim
Con Artist LLC
11:33 PM
Springfield Oregon
I don't know if this is true or not but I've heard some of the stihl vents are somewhat epa restricted.
Also, the foam type filling in fuel filters is necessary for eliminating the tiny air bubbles the vibration of a running saw creates. Milling or long cuts with those things removed can burn a saw up.
