Epoxy in the intake? Ms660
Golddredger
12:35 AM
Paradise, Ca.
Hey fellas,
Keeping seeing in the 660 build threads guys saying they have epoxied the intake. I looked through cant really find any good pictures of this and or why its being done? Can you guys post some pictures and explain why you are doing it? Thanks!
3:35 AM
MS660's are known to have too much exhaust duration. They seem to run better with the exhaust opening down around 100° after tdc. Stock, they vary from about 93 to 98°. In order to get the exhaust port physically lower, the base gets cut on a lathe. This also makes the intake lower. Sometimes too low for good performance. Many consider an 80° intake opening to be about right, but most of the Farmertec cylinders have the intake down around 86. After machining, they get close to 89°, which isn't optimal. Filling the bottom of the intake port with epoxy allows you to grind it down to a more preferred opening height
Deets066
AKA Deetsey
3:35 AM
Awesome! Pictures are worth a thousand words. Thats the visual I had in mind with huskihl description. Now with pictures I am on board 100%.
Port prep is big, definitely wash and degrease cylinder. I like to grind in a few dimples on the floor. Then bead blast
SixGun
3:35 AM
Hackettstown NJ
Cool, thanks ! I heard some guys were using aluminum reinforced stuff.
Doing a couple 660's now and they will need it. Pushing 85* before cutting base.
3:35 AM
Yeah there's fancy stuff out there if you want to pay for it. I've never had jb fail in an intake if the surface is clean with a burr finish. If it did fail, it turns to a soft powder and I don't believe it would cause damage
SixGun
3:35 AM
Hackettstown NJ
Thanks for great info guys. I've been out of the saw game for a bit and never did a full port job on a 660, I usually just did the basics DP Muff, Ign advance, pull limiters.
farminkarman
I like the red & black ones
2:35 AM
Neenah Wisconsin
Question for you guys....when you are prepping for the epoxy, do spray some kind of oil on the piston so the epoxy doesn't stick to it?
farminkarman
2:35 AM
Neenah Wisconsin
I haven't really found gains on filling the intake on an oem 660 jug.....the 661 I have though.
It looks like I'm going to be doing another 359. The last one I did, I elected to not do machine work on it because the intake was already at 80. I'd like to cut the squish on this next one, but I want to keep the intake up at 80...maybe even a little higher. Was wanting to understand best practice for doing the whole epoxy thing.
