Dominant saw V4 371 build
mettee
8:25 PM
Arizona
If your at .016, you could sand out .004 using an old piston with paper on it. Especially if you feel like you are hitting.
If the bearings wear in and some more tolerance happens you might start to really hit badly and wreck the saw.
9:25 PM
I think I'm gonna sell that piston and just build the saw with factory piston. I'm completely out of basic resources. My solder is too thick to begin with and would have to buy solder. Excuses excuses I know but that's my life right now sorry
I'd call up the peeps you got the piston from. If its supposed to be a "plug and play" it shouldn't be given you these problems. Maybe the piston pop up is to big?
mettee
8:25 PM
Arizona
Use a flat top stock piston, slap some sticky back paper on it and trim the rest off with a razor. You can drop that down in the cylinder and spin it and remove the .004 pretty easy. Or if you have a wood mandrel that will work too.
Yeah no need to mess with the dominant piston at all.
Funky sawman
Pony Power
7:25 PM
North idaho
Well, like I said if crap is gonna happen, I'm always found in the middle of a crap storm. So I pulled the ring, reinstalled the thin gasket, and tightened the jug down, no more hitting, turns over smooth. Wtf, this is beyond my current mental capacity
Ronie
10:25 PM
NC
I personally wouldn't run it until I found out how much clearance I had. If your only a couple of thousandths from kissing the cylinder in a spot, you could have a big problem once you start using it.
Funky sawman
Pony Power
7:25 PM
North idaho
The ring looks like its hanging up at the top of the plating. The ring height is further up the piston that the factory single ring
Ronie
10:25 PM
NC
That's odd, never had that happen.
Funky sawman
Pony Power
7:25 PM
North idaho
Well with piston out and ring on piston, it doesn't catch when shoved all the way into bore. But I dont know why having the ring on makes a difference. Weird part is the gasket. One corner is .011, opposite corner is .016. Studying the piston it looks like the chain side of the piston has shiny mark on it but that's it
Funky sawman
Pony Power
7:25 PM
North idaho
Just went through packaging, the gasket was packaged with cardboard backing....NOT A OEM GASKET. it's a hiway gasket
mettee
8:25 PM
Arizona
Get rid of that gasket.
Put the ring on the dominant piston and put it in the bore, push it all the way up and make sure it doesn't hang on the top edge. I forget what they call that.
Canadian farm boy
“Normal” people scare me.
10:25 PM
Ontario, Canada
That’s the ring of death. Where the plating stops before it gets to the squish band.
10:25 PM
You may be hearing the ring when the piston changes direction
Marshy
WFO Cutting
10:25 PM
Mexico NY
Ring of death. Usually after the squish band it turned and there us a small section of the bore that has no plating. Some times it's a smaller diameter than the bore also because it's hard to get the combustion chamber cut all the way against the cylinder wall.
Funky sawman
Pony Power
7:25 PM
North idaho
Nope, I can actually feel the flywheel stop at tdc, without the coil installed. It doesn't take much effort to continue rotating past tdc though.
Funky sawman
Pony Power
7:25 PM
North idaho
Found my issue with the ring......no issue. When I tightened cylinder down with that after market gasket I used two screws on opposite corners, the piston didnt hit. Then I found if I tightened all 4 corners then i have contact. Best case scenario is a factory gasket that's .020 and I end up with .010 squish which is scary tight
Funky sawman
Pony Power
7:25 PM
North idaho
I stuck a .010 feeler gauge on each side of the jug to space cylinder away from crankcase and tightened the jug down, at this thickness the piston just barely kissed the squish band. So I must need a .030 gasket?
