Walter Glover
- 6:14 AM
- Dec 28, 2017
- Alberta, Canada
Getting 1.5hp for Husky 51
3.2hp for the 372xp FT
5.33hp for the ms660 FT
Need more sturdy brake for the 660View attachment 290397
How would he dyno a 2511t? It would have to do 2hp just to read 0hp. Any weaker and the saw would be measuring the dyno's power.
Thinking of connecting an electric motor to measure drag in amps increase and see where that gets meFigure out a way to calibrate 2hp more into your calculations. Then those numbers would be pretty close to stock.
As long as you do a before/after with the same settings the dyno should show a change. Not really a matter of what the numbers are.
Hooked up a motor and with the amp draw and voltage with assumed 80%EFF at a 0.8PF my dyno has 0.25hp losses at 860rpm. As I understand it inertia increases by velocity squared. 3x velocity = 9x hp loss. Therefore 0.75hp lost in spinning the drivetrain on my dyno. That helps the numbers someView attachment 290829
Any guess what took the duce into the next digit hp wise? (and torque too I guess)
Broke in vs brand new. That works out to 4% ish. Not as drastic as it looks.
That's quite a transformation for a small saw to gain 60% horsepower! From a dud to a stud!
What’s it weigh? Is that the light one you mentioned?
Any internal changes compared to the 490? Do you go for lots of compression on them? I think they do great with just a BGD and good porting.
