Well been holding out.
Finally got tired of cutting wood.
Wanted to share my new tool with the class.
First few runs after getting everything all calibrated.
This has a built in weather station, to keep track of temp/humidity.
Those are the sae corrected numbers. Very close to the 660 book specs.
Last week's project making the "bench" and jackshaft.
This is a 30hp rated waterbrake, 17k rpm
Have A 2:1 reduction. Helps smooth out the runs with low tq saws.
Adjustable power head rest with a thick rubber cushion.
Designed it to work with Any power head I could think of. Even raise up enough for belly pipes.
If it can run a std 3/8×7 rim I can run it on the dyno.
Thoughts?
Thoughts?
