- 10:00 PM
- Jan 17, 2016
- Wv
If you take a pic from farther awayCouple teasers....
You can see the whole saw.
Is there any more informationHmmm, those pics are legit. They are NOT from my test saws as they didn't have 592 decals on them. I put a 545 decal on them. LOL
You guys should check out the rear mount layout. You can also see the little steel cable that serves as a movement limiter.
Are these the felling spikes?Hmmm, those pics are legit. They are NOT from my test saws as they didn't have 592 decals on them. I put a 545 decal on them. LOL
There will be some skip in the C83 and C85 at some point. And a full chisel .325 as well.
Some cool bars are coming.
Full chisel. 325... You mean. 050 narrow kerf, like the SP33G ?
It’s just like everything else to suspense can’t wait til it’s overThere will be some skip in the C83 and C85 at some point. And a full chisel .325 as well.
Feed back is that its not a game changer, but it does have some neat features and what not. Guys that are running them say its comparable to a 661 for power but better throttle response. No weight numbers either but I'd say somewhere between a 390 and 661.
Monster I hope it is. What we need to do is get some pictures of the 592 next to 572 ,562 to really compare if it is a monster?That's where it needs to be. If noboby has noticed a weight difference then I'm sure there isn't. That would make sense and follows suite as to what they did with the 572. Same power as 576 and same weight as the 372 xtorq. So 572 came in .3 kg (.66lb) less than 576 on paper.
The 572 has a good bit more power than the 576 thoughThat's where it needs to be. If noboby has noticed a weight difference then I'm sure there isn't. That would make sense and follows suite as to what they did with the 572. Same power as 576 and same weight as the 372 xtorq. So 572 came in .3 kg (.66lb) less than 576 on paper.
Wow my 576's are definitely stronger than the 572's Ive been around. That's interesting
