570 X torq bogs when you give it WOT
changetires
OPE Member
2:20 AM
Mobile Alabama
570 X torq bogs down and will shut off when you give it WOT. Put a RB 130 kit in and it cranks easy and idles well. The adjusters have had the stoppers snipped off and I have tried adjusting them while cutting and not cutting but it will not get to top end. Also tried a new plug doesn’t help. It will run fine till about half throttle then the bog starts happening. Any help would be appreciated.
Rogee
9:20 PM
New Zealand
H
Have you replaced the fuel filter I had one that ran abit like that till I changed the filter and fuel hose
Stevetheboatguy
2:20 AM
Nw IL
I'm going out on a limb here. I can't exactly remember what a 570/575 carb looks like. But is there a chance the strato valve isn't opening properly? I seem to remember them having a goofy linkage set-up.
Steven
cus_deluxe
terms of service violator
3:20 AM
Michigan
the strato on these is a seperate butterfly above the carb, and yeah there is linkage thats kind of a bugger. i assume you replaced/checked the screen in the carb? possibly losing crankcase pulse?
changetires
OPE Member
2:20 AM
Mobile Alabama
All the linkages are working and yes I changed the internal screen. Is the pulse line the small brass tube off the bottom of the carb that fits into the little tubing... it’s kind of a bugger to see and line up when reinstalling the carb?
changetires
OPE Member
2:20 AM
Mobile Alabama
Update
The pulse line was clear and blowing out when I pulled the rope.
With the saw running and I give it enough throttle the saw will start bogging when the lower butterfly starts to open and when you go WOT it starts blowing air out while it try something to bog down.
Is the saw low on compression? I tried to perform a compression test but it would not pump up any pressure on the tester gauge.... am I missing something?
cus_deluxe
3:20 AM
Michigan
sounds like thats a place to revisit...
changetires
OPE Member
2:20 AM
Mobile Alabama
Rechecked the compression again tonight... gauge just flutters when pulling cord and holds zero pressure. Taking the muffler off tomorrow and have a look.
ucm931
3:20 AM
Michigan
Also make sure the compression tester is workin right with a known good saw. Almost sounds like the schrader valve might be loose or something. The guage shouldn't just flutter......it should hold any pressure that builds.
changetires
OPE Member
2:20 AM
Mobile Alabama
Update
Found the piston was scored on the muffler side... took the topend off and the top half of the piston appeared to have experienced some excessive heat.... ordered another 49mm piston kit and a decompression plug and gasket set.... will update after rebuild
changetires
OPE Member
2:20 AM
Mobile Alabama
Update
Cleaned up the piston with some 400 grit.... put a new ring on it.... new base gasket with a light skim of grey gasket maker... new circle clips
Fired off on the third pull and let it warm up and went to cutting WOT
