.325 chain, LGX, LPX or X-CUT?
Joe Kidd
I reckon so
7:33 AM
NC
I haven't had a chance yet.
Lions fan
7:33 AM
Cheboygan, MI
Burned a tank of gas on my experimental loop of S83 a couple evenings ago. Out of the box, It is not as impressive as the Sp33 or the C83. I threw it on the bench and ran through it with a file and lowered the rakers a bit. We'll try it again tomorrow.
ZERO
Simple Life
12:33 PM
Woods & Mountains
I will be giving these a try once my old loops are done.
But to be really honest, once I started touching up after each tank, I am amazed at how much tooth degradation happens in clean hard/soft wood after a tank. That applies to all the major brands.
Squish9
10:33 PM
It changes depending on the wood and how it's been sharpened but I have seen full chisel drop off 10-15% in a tank of fuel. It happens gradually, it still cuts well, just not as fast as it did intially.
There is a crossover point with full vs semi that happens when the cutting speed of the semi holds on and ends up being faster. It can happen reasonably quickly or over a couple of tanks.
Plenty of people will say their FC cuts great after 3 or 4 tanks and it does, but make a few test cuts when it just been sharpened and come back after 2 tanks and make a few more. The drop off is significant
I like the 20/21 LPX/LGX. Nice to file, cuts smooth and holds its edge well. Normally priced very well compared to Stihl here
Joe Kidd
I reckon so
7:33 AM
NC
They work well , I’ve been using them for awhile, with other brands , WCS has some good stuff, Gordy a good dude to .
File plates arrived today. They look to be heavy duty and nicely made. Interesting note..the C33 rakers came in@.025" and they had grinder marks from being set. The C83 rakers were high@.020" and were not touched up. File time.
Squareground3691
7:33 AM
New England
I always give one light swipe of raker , on new C83 chain .
Squish9
10:33 PM
I'll have more info on this later but played with some 325 stuff yesterday
23RS pro - yeah it's fast. Really fast
23RM pro - good luck picking these 2 apart by looks. Pretty damn fast, about 7% behind the RSP
Husky SP33G, fast. Not quite RS pro fast but impressive for a semi chisel
S35G - Less than 2% difference between this and SP33G on a 3hp, 45cc saw. Thought it would be a bigger gap
20LGX, got embarrassed by some of the semi's.
Going to get some C33 or C35 to add to the mix just to see
Forgot to add, Oregon 95TXL - good but not in the same league as the RM pro or SP33. Just not as fast or smooth but was cheaper than both so that's something I guess
