066 Rebuild, Port Job etc
8:39 PM
I use a mandrel with a cutter in it. I would cut .040" out first and then .100" off the base. Then check.
jmssaws
Banneded
7:39 PM
You want to just get the ring where it won't hang, every cylinder will be different but you want to cut as little as possible from the base.
I cut the base first then cut the chamber for a 020 squish. There's a fine line of getting the ring outof the intake and not free porting it. Some cylinders aren't good for it.
Moparmyway
Its just a saw
8:39 PM
In a meeting
You want to just get the ring where it won't hang, every cylinder will be different but you want to cut as little as possible from the base. There's a fine line of getting the ring outof the intake and not free porting it. Some cylinders aren't good for it.
There dang sure is a fine line...... And I'm on the other side of that line, mine freeports. I'll wait for a nice 660 to see how mine runs
Brewz
11:39 AM
Hunter Valley - Australia
I know why I have worked out .060 from the squish
I am measuring direct up and down distance but the distance will change with the arc of the motor.
Brewz
11:39 AM
I will measure it again aiming to stop the ring catching.
Will probably be about .070
