Year end build
8:20 AM
So Joe,
Did you ever epoxy the intake?
What do you think was responsible for the increase in total power?
More upper transfer area? Not enough case compression to push the charge out of the transfers early enough before raising and adding fingers? Fingers helping the flow on the AM uppers?
By adding fingers, all things being equal, you should have needed more BD to fill cylinder properly.
The way I see it is smaller case needs tighter smaller tunnels and transfers and should shift power curve up.
I’m just interested more in the “how” than the actual power number.
8:20 AM
Red97
8:20 AM
MI
So Joe,
I didn't epoxy the intake, altho if I build another, i may go that route, just to see.
The initial setup, was around 100,121,82 and made 6hp at 9500 minimal port work, on the stock carb. Was rather lethargic.
Swapping on just a 372 carb brought that up the 6.6 hp, but still limited with my tiny round to square intake boot. And dropped the peak rpm power closer to 9000.
Round 3, I threw the kitchen sink at it. After looking at how the large carb really helped low end, I knew I wanted to push the power mich higher in the rpm range. This 60cc clutch dosent need to lug down with 70cc type tq.
So, I raised everything up a touch. Ex to 97, transfers to 117 trying to push everything to peak around that 10.5k range. After a slight timing advance it really came alive right up in that range.
Wasn't really worried about case compression, as the 359 has no stuffers and is plenty open.
8:20 AM
Thanks for summarizing it for us Joe.
Maintenance Chief
8:20 AM
South Carolina
So question?, whats the deal with finger ports, why doesn't everybody use them? Are the unreliable with there results?
8:20 AM
Because half the guys think they work and half the guys think that if they help, the transfer ports aren’t big enough or timed right
Stevetheboatguy
7:20 AM
Nw IL
And...... It's extremely easy to completely ruin a cylinder if you have a oops. Or even if you don't have a oops the plating can lift and then....... You srewedagain.......
But yeaahh....... @drf256 @Red97 make some nice finger ports.
Steven
8:20 AM
Steven
It also tends to make them more high-strung. I’ve tried them maybe a dozen times and played with different opening times. Never did much for me. It’s different for others obviously
Stevetheboatguy
7:20 AM
Nw IL
I tip my hat to you guys. All the different recipes and formulas. It's truly impressive.
Steven
Red97
8:20 AM
MI
Lot of work for not much gain. They look cool and may possibly kind of help. Not really a worksaw thing. Mostly race/max effort type thing.
8:20 AM
Red97
8:20 AM
MI
My 266-272 knowledge is minimal but the one you’re calling small might be the normal one. Or might be a 268xp. A 266 is much narrower yet from left to right. Believe they made 200psi stock
Want to say it was off a 268. I know nothing about these other than the bore size and they appear to be in great shape. Pretty excited about the 50mm, as I have a piston in mind that should work out awesome....
Ketchup
Epoxy member
6:20 AM
Colorado
If I can get this hack pile to run, I’ve got a 670 jug that I want to put in a 2159. Small chamber just like the 266/8 but with a boot.
I tried to rush and get the saw together for the So-Cal G2G. Ended up setting myself back. Minor carnage, very rough grinding.
My Dolmar air filter came, and a cheapo 038 piston to replace the 064 slug. The 038 looks much better. The skirt is short enough to clear the case and the rings are lower.
@Red97, I really like the way your kill switch turned out. Where did you get it? I’ve got a stock switch bolted up right now but it doesn’t line up very well.
Also, your timing is 82/97/117? I was close to giving up on this jug, but I think I can get to that zone with the 038 piston. Current numbers are 78/98/114.
8:20 AM
davidwyby
Rural desert logging
5:20 AM
Extreme Southeast CA
I was thinking the 60ccs were round and the 266 and up were rectangular. But my memory may fail me and not as much exp as you. I’ve been through both of mine, but it’s been a while.
8:20 AM
Just trying to help you out a little bit. You usually want to leave .100” above the ring pins. Much thinner than that and you don’t have enough heat sink left and the area around the pins will heat up and spit the pins out. I had it happen on a race 346 that I was building for myself. I had .070” above the pin. Probably saved yourself a cylinder by it failing early.
