Who's running 592s and 585s?
Int1968
7:37 AM
Ontario, Canada
^You shouldn’t have to do any of that when hot starting a saw. If your doing ground work, crane jobs, rigging, chipping when a saw gets used for a short period then sits till the next pick or top. What’s the point of a return to start switch if it won’t start in that position, It’s annoying as f*ck.
After the 3 series they’ve had many bottom end and other issues with the 5 series saws at work. Another tree company the owner tried 3 or 4 562 and gave up, brand new one this year back at the dealer for updates The 5 series are nice when they run right.
andyshine77
8:37 AM
Cincinnati, OH
Exactly. Why have a decomp if you can't use it. The fact they had to make a video with a convoluted way to start the saw, when it should pop with half a pull, like any warmed up well tuned saw. That says a lot! The 550 MKI was a total waste of space, the 562 not much better, and the top handle was LOL bad. I like the 572 and 592 quite a lot, but the other 5 series were/are throwaway saws IMHO.
big_eddy
8:37 AM
Quinte - Ontario
I have two 562, the older one likes fast idle to restart if it’s cooled off a bit. The 2021 restarts one pull on run every time, hot or warm. EL48 carb on the older one. Newer carb on the 2021.
I think the owners manual might even have been updated.
If it doesn’t start first pull, sometimes I need to check which saw I’m holding.
Duce
8:37 AM
Roscommon, MI
I don't get it! All my auto-tune saws have been one pull warm restarts. Just lucky I guess, have times when 4-5 pulls are needed on cold starts, or saw was flooded and needed several pulls (my fault). Some people should just use old carbed saws, they never have starting issues.:risas3:
bradb123
7:37 AM
wisconsin
I brought my 592xp up to my cabin to mess around with . My saw started on choke on the third pull . My saw always starts and runs great !
andyshine77
8:37 AM
Cincinnati, OH
I have never had starting issues with any saw that was 100% if there was something wrong obviously it has a problems, but if everything is working as it should, pop off you go. I'm also guessing where you live you rarely run a saw in hot temperatures with crazy humidity?
Again the fact Husqvarna had to make a video, the fact they had to instruct you not to use the decomp, says there is a problem.
Look I know some some don't like when something about a particular brand is said, but I don't care I have zero brand loyalty, I just report what I see, which isn't necessarily what everyone does. I've stated the best running AT or Mtronic saw I've had my hand on is the 572xp, the 592xp is pretty good too. [emoji3577]
bradb123
7:37 AM
wisconsin
I agree that the auto tune on the 572xp is perfect . I have had zero problems with the auto tune on the 592xp .
Duce
8:37 AM
Roscommon, MI
Maybe they made that video to inform owners of 550xp's how to start their saws, because though evolution of 550xp to 550xpmkII they found starting saws was done by not using decompression valve, so deleted decompression from 550 mkII's. I also could care less which brand of saws people purchase, it's not my money. Don't have a problem starting any of them, that's why I own them, like them all.
Normzilla
5:37 AM
Cazadero CA
Most the time I don't use decomps. Old school I guess. But is it just me, or it seems when a guy even me, does use a decomp, yeah its not as hard a pull. But seems more pulls before firing. On most saws.
pwheel
Finis Origine Pendet
8:37 AM
MA
Yes, although it seems to me that the main advantage of a decomp valve is less wear & tear on the starter assembly.
whitesnake
8:37 AM
NY
How’s the auto tune working for the mk2 550. It’s been out long enough. Pretty trouble free like the 572? I have a ported mk1 that has never given me an issue…I also don’t run it much lol. But when I do she’s a blast! Light, nimble, and lots of power!
bradb123
7:37 AM
wisconsin
I have two 550xp mkll . The auto tune is better than the oe 550xp . IMO it's not as good as the 572xp and the 592xp . That being said , the new 550xp mkll auto tune is good . I have no complaints with it . My oldest 550xp mkll is two and half years old and has been run hard for most of it's life .
