What are you building with your milled wood?
merc_man
merc_man
9:55 AM
southern ontario
Not me, but my back is often sore after I do some milling.
The bending over and pushing the saw does take it's toll!
Thats my problem to. Back hurts after if i do too much.
Got these mapke boards made today. Got three more logs to work on, two maple and a walnut. Just make a few boards a day and its not too bad.
merc_man
merc_man
9:55 AM
southern ontario
I do. I got the Granberg winch because I didn't want to build my own. It definetly helps with the strain on the body.
That looks a lot easyer lol.
Does that have any gear reduction? Looks like its just anpully with a handle welded. If so a cheap guy like me could make one.
gurwald
3:55 PM
Sweden
Made new stairs for the guesthouse, old was rotten.
Was a fallen pine I slabed last year, first time milling, pretty addictive. Cut the boards to size on a tablesaw.
merc_man
merc_man
9:55 AM
southern ontario
So whats better? To push mill straight down the log or go like a seasaw. It seems way quicker going like a sea saw vs straight down.
Sorry for the newby questions haha. Just getting into this and its kinda addictive.
merc_man
merc_man
9:55 AM
southern ontario
Square filed chain leaves better finish than round filed chain too. In my experiences.
So for my first chain I just conerted my regular full chissel by grinding to 10 degreese. I will eventually try a propper.milling chain bit if I am gonna just convert a couple for now, whats better a chissel or semi chisel chain?
9:55 AM
IMO, for milling, I like square file the best, but have also used narrow curf chain. Stihl narrow curf for milling is only available through Logosol.
Stihl dealers can't get it.
9:55 AM
I seesaw when I mill, especially if the slab is hard and wide.
I think it puts less stress on the saw, and leaves a more attractive pattern.
I don't plain the wood, or fully sand the lines out.
gurwald
3:55 PM
Sweden
A bit OT but I am looking to upgrade my mill I can only cut 24" wide at the moment, going to need a new bar as my biggest is 30", will 3/8LP cut faster than standard 3/8, is it narrower kerf and easier on the powerhead? Im considering a 42" gb 3/8lp bar with oregon 3/8lp ripping chain, chain is called 91R.
I thought 3/8lp was used for small saws so question is if it will hold milling on a husky 394?
9:55 AM
You can only use full chisel to convert to square. Semi chisel will not work at all.
I just use regular 3/8" chain.
merc_man
merc_man
9:55 AM
southern ontario
Finally got a spot set up tonstacknthe boards out of my way. Under the deck. I put tin up as a roof years ago so it wont get rained on.
Now I am at a stabd still. I ran out of fuel lol. The saw sure does like to drink
Joe P
8:55 AM
Wisconsin
Haven't built anything yet, but I have big hopes for these cherry slabs. Norwood PM14 mill. Saves the back as I can mill standing up. Worked great once after playing around with getting the log on the bunks.
20210821_173949.jpg 20210821_173953.jpg 20210821_180539.jpg 20210821_193607.jpg 20210822_132359.jpg
