What About Those 036 Kits? The "Bottom Feeders" Of The Kit Saw World?
Jughead
4:22 PM
No press needed Jake.the only thing I press is bearings coming out of the cases on a rebuild and it's only a small portable one from harbor freight that was less than $50.
Installation gets done with a heat gun.
Mattyo
Youtube speciawist
4:22 PM
Farmington, CT
if they offered a stihl 290/310/390 kit i would build one because i don't have a press.
No need for a press
Heat gun or torch on pto side....then pull flywheel side through like this:
I'm taking notes on walts vids...they r very helpful.
4:22 PM
I just toss the chinese decomps to many failures but some like them is there a good non oem cheap one out there.
4:22 PM
i thought the a frame one wasnt big enough opening
BuckthornBonnie
4:22 PM
Penn Yan, NY
Walt--- welcome to the 1125 series! As you said, they're one of the easiest saws to work on. Heck, only one stud holds the cylinder top cover on! Lol.
Im curious as to what Huztl provided for the oil line (the notorious connection between pump and outlet). Ive used alternatives to the stihl line with success.
afleetcommand
4:22 PM
CNY
I saw those and was thinking of taking the bottom "guide" bar the press goes through and re mounting it up on the "A" a bit. Would add a few more inches. You really don't need a lot of force and one of these presses enables so many other saw & outboard & motorcycle type projects. I hate using a flame around the nylon caged bearings & even heat. Maybe a max of 250 degrees (F) as I did on the Husqvarna's. And for the $100-$150 it is one of those enabling tools, one you wonder how you lived without for so long if you do this type of stuff. The bench top...maybe modified for the saws could also solve "foot print" issues with folks with space issues....
A press, a heat source (I use a paint stripper "hair drier" on steroids), A non contact thermometer, and sockets get you a long way in these things. Of course a drawer full of Husqvarma & Stihl shop tools to pull cranks and set seals is nice when "Farmer Joones" technic fails...but to this point on the "Kit Saws" I haven't needed anything special really. I use the press because its easy & I'm always time constrained. I did a 254 in a damn bench vice! (Big one)
afleetcommand
4:22 PM
CNY
When money is available again, I would like to get a big arbor press. Used them a lot working on Mercury Outboards installing bearings in those bearing caps...need a 12x12x12 cube really. Big arbor presses may be obsolete & hard to find....but they give you a better "feel" when working these things.
afleetcommand
4:22 PM
CNY
Just found this on YouTube, a reminder we are dealing with people who also work their tails off and like us, doing the best they can...:) And what I have found to this point they respond to feed back, a one hand washes the other deal.
