- 3:35 PM
- Jan 12, 2016
- Iowa City
Impressive.The final result after finishing back the welds and carefully trueing the deck surface by hand with a file and a flat plate and some 400g sandpaper. The case gasket surface was trued with 400g on a granite block.
View attachment 408482 View attachment 408484 View attachment 408485
Nice job on the repair! I’ve never welded magnesium. Does it TIG similar to aluminum?
Nice work, as usual. May I ask why you didn’t use AZ92 filler? Did you switch it up?The final result after finishing back the welds and carefully trueing the deck surface by hand with a file and a flat plate and some 400g sandpaper. The case gasket surface was trued with 400g on a granite block.
Great work!
What tungsten did you use? Argon or helium?
I did my first repair with az92, definitely a learning curve. I kept getting lots of porosity.
you've inspired me to dust off the syncrowave. I assume I'm cranking the balance to 9? turning the little amp knob to 200.. mashing the pedal and magically beautiful stacks of dimes will appear ?
no stacks of dimes were had. fooling around a bit on a junk case to see what I could do about fixing the mating surface...
had the machine at 85A, but didn't need all of that to get a bead going on the edge. 2% ceriated, straight argon, AZ61A, left the balance at 9. I'll play with the settings some, but seemed to go ok for the first time with mag
thanks for the moment of inspiration. your post reminded me that I had picked up a tube of mag filler rod a few years ago to fix some dolmar cases that have been on the shelf even longer.
2% ceriated, argon 35 cfh with a #10 gas lens.
I’ll have to pick up some ceriated and bump my gas next time. Hopefully it holds
Ceriated isn't necessary. My welder seemed to like it a little better for low amp arc starts, that's all.
You should build the spike side back up. That area is supposed to be flat but it has been worn into by the spike.
That’s a shít-ton of Ar. I’m much cheaper and go 10 on Al and 8 on steel with a #8 lens. You really feel that 35 is necessary for Mg?2% ceriated, argon 35 cfh with a #10 gas lens.
