WOODS
11:15 AM
UETN
No. My attention deficiency gets in the way. Lately, I've been working on trying to learn proper chain filing. Ron
11:15 AM
I need to come visit you again.
WOODS
11:15 AM
UETN
Only recent MAC "work" pictures I have:
Special bar design I have been working on to reach around the stem to trim branches. Seriously this was the best I could field straighten a 45 degree bend resulting from hanging the MAC in a supporting tree. Friend at a machine shop finished straightening it.
Mike, just give me a call some time. I could easily put together two small carb kart saws but I really wanted to build a sleeper with a big BDC under the hood. As to sharpening, I just want to get good enough for consistent firewood work - no racing for me.
Ron
11:15 AM
I will next time I get some time off.
Guido Salvage
Supreme saw hoeder
11:15 AM
Farmville, VA
Couple of ancient boat anchors in my collection.
WOODS
11:15 AM
UETN
A little MAC workout today.
I love the SP125C. Cranks easier than my MS361. 26 degrees and two year old mix in the tank. All the dirt on the wood wore me out though.
Ron
WOODS
11:15 AM
UETN
Some Upper East Tennessee scenery from today - view from cutting site:
Ron
PS to Mike Lee: PO is a boiler maker and inspector. He didn't recognize your name but thought he probably knows you. His name is James Knight; early thirties.
WOODS
11:15 AM
UETN
Probably. Pretty common vine around here. Fortunately, it doesn't usually bother me much. Ron
Canadian farm boy
“Normal” people scare me.
11:15 AM
Ontario, Canada
Can anybody help me identify this old Mac? Maybe educate me a bit about it as well. I have never worked in a saw this old. I can't find any serial number or model number. Buddy of mine just gave it to me. He figured I'd like it. He was right. I plan on doing a full resto on it at sometime.image.jpegimage.jpegimage.jpegimage.jpeg
Steve
Excellence!
10:15 AM
It's a 15. The serial number is stamped in the lower handle around the carb area. 80cc from around the early/mid sixties. Uses the same carb kits as a Tillotson HL but less the diaphragm since it is gravity fed.
Ikeholt
11:15 AM
indiana11
20160209_163124.jpg Hey Mark, Don't you have that pump running yet? I cut a jag of wood with the BP-1. I'll try to attach a pic.
heimannm
10:15 AM
Dike, Iowa
I have been collecting literature and documentation for some time, recently I decided to go through it all and try to get it somewhat organized. I have the IPL's pretty well sorted out and filed using some vintage McCulloch binders. In addition to the saws I have an assortment of generators, blowers and vacuums, string trimmers, brush cutters, edgers, hedge trimmers, power washers, gas powered drills, etc.
I also have a stack of duplicate IPL's so if anyone has a specific need, I may have one for you.
I few that I don't have (original copies) include:
73
73A
1-45
1-62
1-75
1-81HD
PM570
Titan 560, 620
If anyone out there has a spare of any of these I have lots of trading stock.
Mark
Mark71gtx
11:15 AM
Fuquay Varina, NC
I assume my 380 (magnesium, not the plastic one) came with bar guide plates. I have seen a few on eBay, but there are different sizes. What set should I use for my saw? I have attached a picture of the mount end of the bar I have for it. There were no plates on it when I got it. If someone has an extra set for sale that will work, I would be interested IMG_20160216_210747966.jpg
heimannm
10:15 AM
Dike, Iowa
There are quite a few part numbers and designs that will work on that saw, best bet is to buy a set for the large frame saws (3/8" bar studs) and have a go.
The 380 should have the bar adjuster in the clutch cover and won't use the scalloped slot in the bar for adjustment, that's a good break.
Mark
Mark71gtx
11:15 AM
Fuquay Varina, NC
14556785466661839674323.jpg Thanks. I am buying all of the old McCulloch inventory from a local saw shop on Friday if all goes as planned. He has several NOS parts of that vintage there. With any luck there will be a set in one of those boxes. I know there was a few of the canister mufflers and at least one bottom handle brace to fit that saw in the parts I have seen. I already picked up a muffler from the batch!
