WOODS
7:31 PM
UETN
No. My attention deficiency gets in the way. Lately, I've been working on trying to learn proper chain filing. Ron
7:31 PM
I need to come visit you again.
WOODS
7:31 PM
UETN
Only recent MAC "work" pictures I have:
Special bar design I have been working on to reach around the stem to trim branches. Seriously this was the best I could field straighten a 45 degree bend resulting from hanging the MAC in a supporting tree. Friend at a machine shop finished straightening it.
Mike, just give me a call some time. I could easily put together two small carb kart saws but I really wanted to build a sleeper with a big BDC under the hood. As to sharpening, I just want to get good enough for consistent firewood work - no racing for me.
Ron
7:31 PM
I will next time I get some time off.
Guido Salvage
Supreme saw hoeder
7:31 PM
Farmville, VA
Couple of ancient boat anchors in my collection.
WOODS
7:31 PM
UETN
A little MAC workout today.
I love the SP125C. Cranks easier than my MS361. 26 degrees and two year old mix in the tank. All the dirt on the wood wore me out though.
Ron
WOODS
7:31 PM
UETN
Some Upper East Tennessee scenery from today - view from cutting site:
Ron
PS to Mike Lee: PO is a boiler maker and inspector. He didn't recognize your name but thought he probably knows you. His name is James Knight; early thirties.
WOODS
7:31 PM
UETN
Probably. Pretty common vine around here. Fortunately, it doesn't usually bother me much. Ron
Canadian farm boy
“Normal” people scare me.
7:31 PM
Ontario, Canada
Can anybody help me identify this old Mac? Maybe educate me a bit about it as well. I have never worked in a saw this old. I can't find any serial number or model number. Buddy of mine just gave it to me. He figured I'd like it. He was right. I plan on doing a full resto on it at sometime.image.jpegimage.jpegimage.jpegimage.jpeg
Steve
Excellence!
6:31 PM
It's a 15. The serial number is stamped in the lower handle around the carb area. 80cc from around the early/mid sixties. Uses the same carb kits as a Tillotson HL but less the diaphragm since it is gravity fed.
Ikeholt
7:31 PM
indiana11
20160209_163124.jpg Hey Mark, Don't you have that pump running yet? I cut a jag of wood with the BP-1. I'll try to attach a pic.
heimannm
6:31 PM
Dike, Iowa
I have been collecting literature and documentation for some time, recently I decided to go through it all and try to get it somewhat organized. I have the IPL's pretty well sorted out and filed using some vintage McCulloch binders. In addition to the saws I have an assortment of generators, blowers and vacuums, string trimmers, brush cutters, edgers, hedge trimmers, power washers, gas powered drills, etc.
I also have a stack of duplicate IPL's so if anyone has a specific need, I may have one for you.
I few that I don't have (original copies) include:
73
73A
1-45
1-62
1-75
1-81HD
PM570
Titan 560, 620
If anyone out there has a spare of any of these I have lots of trading stock.
Mark
Mark71gtx
7:31 PM
Fuquay Varina, NC
I assume my 380 (magnesium, not the plastic one) came with bar guide plates. I have seen a few on eBay, but there are different sizes. What set should I use for my saw? I have attached a picture of the mount end of the bar I have for it. There were no plates on it when I got it. If someone has an extra set for sale that will work, I would be interested IMG_20160216_210747966.jpg
heimannm
6:31 PM
Dike, Iowa
There are quite a few part numbers and designs that will work on that saw, best bet is to buy a set for the large frame saws (3/8" bar studs) and have a go.
The 380 should have the bar adjuster in the clutch cover and won't use the scalloped slot in the bar for adjustment, that's a good break.
Mark
Mark71gtx
7:31 PM
Fuquay Varina, NC
14556785466661839674323.jpg Thanks. I am buying all of the old McCulloch inventory from a local saw shop on Friday if all goes as planned. He has several NOS parts of that vintage there. With any luck there will be a set in one of those boxes. I know there was a few of the canister mufflers and at least one bottom handle brace to fit that saw in the parts I have seen. I already picked up a muffler from the batch!
