- 10:12 AM
- Jan 26, 2016
- South west UK
that’s the bar and seeing it’s 33” the 106DL would make sense
I have 92 links on my 28" Mac bar.
I may be wrong but if memory serves it's 104 drivers for a 32".I'll trot out in the garage some time today and find a bar as I have several .I think they are Windsor patterned Macs made in Canada in the 70's My Stihl 32's are Oregon .
I'll second that. 106 drivers should be the ticket. Stihl 32" bars in 3/8 pitch usually take 105 drivers. I stock oregon 72jgx chain which is full skip full chisel. Do you want a loop?thanks that’s the one sounds bout right
I've moved on from the little beasts for a bit.I've got a couple of RH 10 series clutches that need attention.How do I get this PITA clutch together?View attachment 322793
If youve done one before, that is an excellent answer. Thats how i did them. If you have trouble send it to me. Ill put it together and send it back.
Marshall county, northern panhandle. Closest town is cameron.
No need to clarify Steve,I know exactly what you're sayin'.I was doing it on my kitchen table & damn near had it.If God would've only given me my much needed 3rd hand,Lol.I'm afraid if I take this out to the garage the springs & guides are going to get lost.Getting that guider up through the spring is quite a feat in itself.I still have the clutch that was missing the guides from back last summer/fall.If I'm successful with one I'll do the other.I don't understand why Bob J.sent it to me in pieces.Put the clutch just the way you have it in a vice. Jaws on the center of each shoe with one side with the springs up. Put a spring guide in a spring and hook one side onto a shoe. Then use a screwdriver to lever the spring onto the other shoe. Flip the clutch in the vice and do the other side the same.
I can take some pics of the process tonight when I get home to clarify a bit better.
