- 1:23 PM
- Jan 14, 2016
- North western Ohio
I wore part of mine off on the head board .I said that once then it all fell out![]()
Got some nice ones in there!Happy New Year folks! Here's a few of my yellow toys.
OK,I have it together correctly then.The problem is that when I tried to use it it will only "lock"when I push the throttle lock down,but it's not catching on anything.I pulled the trigger to move the part of the carb out of the way so the throttle lock would lock in place.Obviously unsuccessful.This is the correct order and position for the parts. Those throttle locks are often a problem.
Mark
Just gotta use those sparingly.Got some nice ones in there!
Alot of green oiler buttons in there though? Wouldn't be safe around me, I've broken most if not all mine and had to replace them with black ones.
Really?Is it that slow here?Lol OK,I'll give your minds something to try 'n figure out.
Trying to put the carb cover on the Monkey Wards 2.1 & I'm having some problems.
1)For the AF bracket (had to replace it due to a moron using the wrong screw resulting in stripped threads) what is the order for the washers & choke plate?I've figured that the top of the bracket gets only the thick washer,but the bottom is a bugger.There's the thick washer,the wave washer,& the choke plate.
2)I put the throttle lock into the carb cover,but not sure if I got it in right or not.I couldn't get it to go on the other way (the aluminum cap)
- edju1958 · Jan 2, 2022 at 4:50 PM
I have 92 links on my 28" Mac bar.AJ - I can't help on the 32" but my 28" bars are 92 or 93 DL of 3/8 pitch chain depending on the actual bar. I don't think I have an Oregon branded bar, only the Windsor/McCulloch and maybe a rebadged Echo.
Mark
Thank you mark for thatAJ - I can't help on the 32" but my 28" bars are 92 or 93 DL of 3/8 pitch chain depending on the actual bar. I don't think I have an Oregon branded bar, only the Windsor/McCulloch and maybe a rebadged Echo.
Mark
