- 4:52 AM
- Jan 14, 2016
- North western Ohio
I just had good luck getting some stuck parts free with a little heat and a "quench" with Kano Aerokroil.You might try soaking them in a shallow tray with some Sea Foam motor treatment. Good stuff.
Mark, I would personally try a combo of aluminum brightening acid, soaking in a shadow tub. Then soaking in evapo-rust. , the acid will neutralize the aluminum oxide and the evapo-rust will get the rings.I am starting with the ultrasonic cleaner since I have that available here and now. Looking at the piston after it has dried out from the mineral spirits parts washer, it looks like aluminum oxide more than carbon in the grooves, end gap, and on the lands. I may have the opportunity to try several different techniques on this one. I do have spare rings so I don't need to save these, I just need to make sure and preserve the piston as best I can. The piston actually looks better in hand than it appears in the photos.
Mark
be careful to not soak to long in acid.
Heat, spray, cool with a quick water dip, repeat.
When they let go, blow dry and coat with oil or Kroil.
Again, not much heat at once.
Rings and piston are used to temperature changes, just dont want too much too fast.
This flat out works!!50/50 Acetone and ATF in the heated USC. Use a separate container sitting in the normal USC solution if the USC is large enough.
No.Is there an easy way to look up part numbers to see what things are?
I have three large bins full of nos labelled McCulloch parts from buying out a dealer a few weeks ago. Is there an easy way to look up part numbers to see what things are?
No chainsaw body or handle parts, cranks and only one smallish cylinder kit but probably about 1000-1200 parts with part numbers.
Same with Homelite, Briggs, tecumsah, Jonsered (inc NOS plastics), oregon, herr, wico, niehoff, stens, napa, couple hundred name brand spark plugs, GB, weedeater, ryobi, a little husky and Stihl, poulan, poulan pro, John Deere, even an assortment of belts, spindles, blades etc.
Woots!!!I'll call dibs on behalf of @cuinrearview on all vintage John Deere edger blades, and on behalf of @huskihl for all vintage bump-feed Homelite string trimmer heads.
It pays to have friends.I'll call dibs on behalf of @cuinrearview on all vintage John Deere edger blades, and on behalf of @huskihl for all vintage bump-feed Homelite string trimmer heads.
I think my problem was the mixture separated after sitting in a squeeze bottle a long time . I'm not certain if the tranny fluid was Dexron or synthetic . The idea is good being the thinned down tranny oil would be carried with the mix and get into the parts then evaporate leaving just the tranny oil I think .This flat out works!!
