Mig_Selv
- 3:45 AM
- Nov 22, 2024
- The Arctic Circle
That was autocorrect. Should have spelled F-A-G main bearing $14, and SKF regular bearing. The F-A-G bearing is the one you pay quadruple for from Stihl as OEM. Stihl doesn't make bearings, F-A-G, INA, and SKF makes 99% of the bearings out there, Fafnir makes the rest.All saws have c-3 bearings oem because it’s a clearance rating that they don’t get too tight when warmed up. And you made the saw worse than before by using cheap bearings in place of oem but to each their own. Who cares if they standardize the electrical on the saws most won’t buy a scan tool unless it’s 50$ anyway and like I said the mdg1 isn’t needed on mtronic most times.
I think a lot of people would care if they made a standard diagnostic tool, but you are correct, the current tool is junk.
EDIT: It seems the auto censor replaces the name of the ball bearing manufacturer F-A-G with the word "slacker", wasn't a typo.
