Stihl 046/460 D Jug. Are there benefits using it on a 460, or better using it on a Hybrid?
6:48 PM
The D cylinder certainly has a nicer looking combustion chamber for those of us who do not have the ability to cut the squish band.
I plan to build a saw with each, hopefully with base gasket delete, and see what runs better. I think I will have to sand the squish band in the H jug to get it to work with a base gasket delete. Would like to see how the differences in port timing play out in that scenario.
Seems like I should be able to delete the D jug gasket w/o any problem, much easier!
6:48 PM
Interesting, seems like this refers to the change from the D cylinder to newer ones? But the D cylinder is more favored by people? 063F1006-35DE-4AE6-A84B-1C4D206308AD.png
6:48 PM
Mason, the old 044s were rated at lower HP than the new 440s. You have run both ...
6:48 PM
Probably just better port timing. Prior to EPA getting involved to curtail any "exhaust waste."
Deets066
AKA Deetsey
6:48 PM
What interests me is that it says the old cylinder is still available as the low compression version. Never noticed much change in compression being the old one having less?
6:48 PM
I had a Hemi chamber 046 that had 175 PSI stock, but it would not out cut my 044 till I sent it to Bret.
6:48 PM
That may be the 046 Magnum … and how do you explain their comment "increased power"?
The first year 046 Mag came with a DP muff cover, from the factory. 044 never did.
066 did also, and they rated it 1/2 HP more with the DP cover.
I know the early 044s were rated at lower HP. Comical that the ones with the little 3/8" muff hole were rated lower than the ones with large 5/8" muffler hole. I guess it comes down to HP#s, Powerhead Weight, and Magnum stickers sell saws!
Canadian farm boy
“Normal” people scare me.
6:48 PM
Ontario, Canada
Any advantages of one over the others?
Lots of variables to consider. Cylinder port timing stock. Where you want it to be after porting etc.
Compared to a 046 piston the 064 piston has a lower crown height and iirc longer skirts and the pin bosses are wider as well.
The 272 has a higher crown height and a single ring.
I haven't played around with the wiseco piston yet so I can't comment on it.
Your piston choice just depends on the type of build your doing and what you want the end result to be.
Deets066
AKA Deetsey
6:48 PM
Agreed, except that the 064 is .060 taller than a 46
272 is .100 taller
6:48 PM
So Wiseco is better for cant cutting?
What's the matter with the 046 piston?
Does an 064 piston make for better work saw?
