- 7:31 PM
- Dec 29, 2015
- Strong Island NY
441 is quad and strato IIRC.441 is quads right?
Transfer would be different
I don't think those designations had anything to do with port timing.Well if the factory changes port timing on the same model upgrading it to a magnum or super then I don't consider that stock, I consider it a mass produced ported saw.
That is a definite no, but I'm not sure about a 461 jug on a 441? Never had a 441 apart, but they are both quad port saws.
But Stihl had discovered that putting a "Magnum" sticker on the saw sold saws, so numerous saws got Magnum stickers that had absolutely no performance advantage. This was just slick marketing, and it worked. I have talked to people who sell used saws, and buyers want that Magnum sticker, cause they believe it will run better.
you're absolutely correct mustang....I overheard one of our salesmen on the floor the other day talking to a customer about the br600 and the br700...the guy almost didn't buy the br700 because it wasn't a "magnum"....those stickers are like voodoo.
Some do, most don't. I was pointing out the fact that factories have also hopped up saws and mass produced them that way while still selling the same model in original stock form, which in my opinion they're not stock anymore and mass production shouldn't change that fact.I don't think those designations had anything to do with port timing.
And it wasn't too long after Dirty Harry made the .44 magnum so popular.I can't speak for every model, but for the 046/460, that is just not the case. The early 046 & 066 magnums were so designated because they came with a dp muffler, and in the case of the 066 I believe it added approx 1/2 Hp.
The EPA soon banned the dp covers, and even made the makers reduce the size of the original muffler outlet hole. I believe this may have been why Stihl had to re design the combustion chamber in the 046/460 to produce less heat. You generally can not delete the base gasket on a 460 like you can on a 440 (all 044/440s had D chambers), and my stock round chamber 046 had 175 psi from the factory (but ran like a dog).
Ignorance is bliss!
Right where I was and I checked a few times. I checked the D jugs twice on a 460 case and once on a 440 case because the member who sent them said he got 42 squish. I came in at 30-32 on the D's. so I intentionally left the squish tight for fine adjustment in his shop. He can add whatever gasket material he wants.The 2 I've deleted gaskets one were .019 and .022" without gaskets.
Eyeballing it only, I'd bet 40% band/chamber on the Hemi and 60ish with the D.D must have a wider squish to start then
I haven't ported but maybe a couple saws in the last 6-9 months.
