So what did you do today?
fearofpavement
8:03 PM
Georgia
The other day Groundie was running her MS180 and it went "pow!" and quit running. Seemed to have no compression. I was thinking she threw a rod or something. Today I started investigating it and discovered the spark plug had blown out. Easy fix. I was happy. The threads weren't stripped so it must have just slowly backed itself out.
hoskvarna
7:03 PM
Iowa
You is lucky [emoji2957]
I’d rather be lucky than good [emoji106][emoji6] lol
Sent from Hoskey hilltop
Maintenance Chief
8:03 PM
South Carolina
hoskvarna
7:03 PM
Iowa
Stem
Professional Cup Stacker
8:03 PM
Pennsylvania
parts showed up late Saturday evening for the 154. new rear flywheel, pilot bushing, friction disk, pressure plate kit, throwout bearing, linkages, clutch brake parts & some misc hardware. took a while to get everything set correctly but it's done & shifts like butter.
also tore the PTO clutch assembly apart, replaced the clutch drum & did a much needed cleaning on the plates & steels, changed engine oil & filter, spark plugs, flushed radiator & put new coolant in, new battery cable ends, hyd filter, rear diff & final drive fluid, fixed & loomed some wiring & put new wheel bearings in the left front wheel.
only things I still want to do is check/adjust valves & replace the generator belt, it still has the original belt on it.
Wonkydonkey
Plastic member
1:03 AM
Sussex, UK.
Put this post & rail fence up today & yesterday with my mate. If you look closely behind the aris rail fence ( the feather edge will be fixed on later, it’s for a bit of privacy around the door area) there is about the same amount of post & rail behind it.
1. Corner and small 3’ length, then post & rail to end of building.
2. End of building
gurwald
2:03 AM
Sweden
Took three weeks vacation, I like this time of year the best when it goes from early spring to full bloom in a couple weeks.
Finished splitting this birchtree, most of it fit in the back of the truck. photos are a couple days apart.
Started building a shed, going to mill the floorboards and some beams from two large spruces.
hoskvarna
7:03 PM
Iowa
Nice truck [emoji106]
