So what did you buy today
heimannm
3:23 PM
Dike, Iowa
I have the Carlton version of the 511A, I was not too happy with the results using the pink vitrified wheels but once I spent the $$ and got the CBN wheel I was very pleased. I sharpen a lot of 3/8 LP and .325 chains for locals so I leave the 1/8" wheel on the Carlton all the time.
Mark
el33t
10:23 PM
Poland
Out of curiosity, what was your main problem with them?
You can also sharpen 3/8 standard chains with a 1/8'' wheel.
You just need to be more careful not to grind too deeply into the cutter if you want to avoid too small a side plate angle.
A long time ago, this was the standard wheel thickness for 3/8. Currently, Tecomec allows the use of such a wheel for everything from 1/4 to 3/8.
Partner
10:23 PM
Poland
I would buy this 4.0mm 5/32" wheel, but it is not available here
heimannm
3:23 PM
Dike, Iowa
I felt like the vitrified wheels loaded up or glazed over very easily leading to overheating of the chains. Grinding seems to be pretty slow as well.
I do have a 1/4 wide vitrified wheel in one grinder that I use exclusively for the depth gauges and I don't have any complaints about that one.
I have a 3/16" CBN wheel in a newer Tecomec grinder for 3/8" and .404 chains so I don't have to change them.
I put the three chain grinders and the Bailey's bar rail grinder on a "lazy susan" so I just rotate it as needed for each task.
Mark
Partner
10:23 PM
Poland
Today such a patient costs $5 😎👍38 years old, quiet for now, I have never seen a speed sensor on the fan in a drill. Faulty cable? That would be too easy 😉 The switch is stuck, lubricate the rotor bearings and look into the gearbox / The gears must be switched with a screwdriver 1 and 2
Partner
10:23 PM
Poland
The switch is good 👍 the engine starts only after a moment of consideration 😉 there is an RL lever above the switch, but in this model it serves a different function of limiting the pressure of the switch, so there are also 2 different speed / Good old Wesfalia 4000 on the Internet you will only find Chinese drills under this name
They call me Mr. Kibbs
4:23 PM
Wandering the VA woods
Obviously I don't get out much, 60 years old and the only time I've ever heard the term Westfalia is
1754077536771-png.466021
Bill G
3:23 PM
Mark
Where is the pic of the Bar Shop?
