- 2:38 PM
- Dec 29, 2015
- Strong Island NY
Look Closer...I see alittle extra but not in the uppers.
There's more in the uppers than meets the eye. Basher would be correct here.
not to derail the thread but how well do the 44mm 026 perform modded, ported?
i might price a 44.7mm top end from stihl muhahaha.mine is a 44 mm
@Stihlbro has one for sale.i might price a 44.7mm top end from stihl muhahaha.
I have an NWP 44.7 on my bench right now. @Definitive Dave has them in stock.
The quality is the best I've seen so far in an AM jug. I plan on timing it soon and doing a build thread with one.
So......
I made the fatal mistake of trusting that the member that sold me the saw checked everything out before the sale. Second mistake, not running it before I ported it.
So it passed the vac test after the jug was set on, but I had left the handle and carb intact. The WT194 was apparently new.
Last time I'll do this. So I think I found the idle issue. No ring in the boot and a torn impulse line. I will run it again real soon.
The piston is fine thank god. View attachment 34429View attachment 34431View attachment 34432View attachment 34433
The last guy that touches the saw is "it".
It's the saw you sold me. I don't think you did anything intentionally and it was a cheap fix. I changed the lever because Jeff liked the red lever look.Hey, Al. This isn't the 026 I sold you, right? It sort of looks like mine, except for the red lever and rusty muffler.
I can be a dumba**, but I'm a honest dumba**.
I'm not sure. It's in the round file now.Did the implulse line have the Stihl "S" emblem moulded into the end which fits the carb. It looks shiney like a cheap chinese line -- they are way too soft for me.
The fuel line is it oem or no?
You boys made me curious, so I tossed the NWP on my builder case.
The potential for this jug is impressive to say the very least.
Base thickness is .280-300. That's 30 thicker at its thinnest point as compared to any factory 026/260 I've met so far.
The exhaust port is the typical AM smaller area port and the ex roof needs cleanup.
But the numbers look great.
Prelim are 101/122/69 with no gasket.
I'm pretty excited about this jugs potential.
I'll post squish measurements and porting pics as time allows. Will do a build thread.
My plan will be to build one for the CT GTG to run against the other 4 DRF026/260 that will be there.
