removing paint from guide bar or tip
Magnumitis
Kevin in Arkansas
2:28 PM
yes
I have many electric brushless RC cars and trucks. I use IR temp guns to check motor can temps to set up proper gearing. I remember a few years ago reading, (more than once) on RC forums, that different finishes on metal motors can affect temperature readings. Different colors/painted any shiny surfaces can give different temp results. I think IR Guns can't always measure temps properly on shiny surfaces. I tried to search for some of the discussions that I read, but couldn't find them. But I did find this...
http://www.raytek.com/Raytek/en-r0/IREducation/Emissivity.htm
This write up seems to say that you'll get the most accurate temperature reading of a shiny surface if you paint it black.
From what I gathered, polished steel would give a much lower reading.
Keith Gandy
Maxima K2 40:1 87 Pump Gas
2:28 PM
Provencal, Louisiana
FWIW I have never owned a vehicle that didn't have a painted radiator. Evaporators and radiators serve reverse functions. The former collects heat from the outside air and transfers it to the circulating refrigerant; the later collects heat from the circulating coolant and transfers it to the outside air.
I don't know if a chainsaw bar acts as a cooling fin or a heat source in normal applications as I don't know the temperatures of each component, but the principles T1 raise are correct - heat moves to the cool. Gloss surface reflect more and dull surfaces absorb more. Interesting test would be operating chain temperatures on a clear coat bar, a flat black bar and a bare bar. Same test for temperatures at bar mount.
Ron
R u saying the tubing and fins on your vehicle radiator have paint on them?
Magnumitis
Kevin in Arkansas
2:28 PM
yes
bigbadbob
12:28 PM
Interior BC Canada
I just got a double sealed quick connect muffler bearing for my ported Cummins,,, gonna scrape the finish off then have it ceramic coated for better cooling,,,,Im betting on 25 HP gain!!
BBB
WOODS
3:28 PM
UETN
KG, IDK but it may be more of a corrosion measure for copper and brass. Some aluminum radiator tubes aren't painted. Ron
WOODS
3:28 PM
UETN
I wonder if its some sorta special paint? For emitting heat?
Once again I don't know. May also be for aesthetics. I worked for awhile in the early 70s with a distributor of Moline radiators. IIRC they were all a glossy black. Though it doesn't take long for grime to dull them out. Heater cores were bare. Ron
KenJax Tree
¯\_(ツ)_/¯
3:28 PM
Over there
I found a solution
hseII
Heef
3:28 PM
West Georgia
What a shame
That was right before the Tragic Boating Accident.
All my accessories were lost too.
I now have a Glock brand rape whistle, but never get a chance to practice using it.
I understand once I have honed my skills, the Flying Circle J is the place to be.
