Play time?
Red97
4:59 PM
MI
Has some holes..
Need to set squish, it hits by about .005"
Then I will put in the degree wheel and draw a line where I want the transfers. Was too chicken to poke them in blind.
Lots of work on the lowers, at that diameter they were tiny...
Red97
4:59 PM
MI
Can you run me through the pros and cons of going this route instead of replating. I guess the diy aspect is obvious and I'm really interested in doing something similar with a 3120 cylinder I have.
That is about the only pro... diy
May be an option for a worst case scenario jug.
But for the 200-280$ it cost to have one bored and coated with nikasil not sure if it is really worth it..
Actually if I didn't really enjoy this, just to see what I can do, I would send it out to be done.
I have 30$ and about 14 hours into this one sleeve. Now I could probably get that down to 6-8 hours but still...
traffic903
6:59 AM
Australia
And are there any issues in terms of using the cast iron? For example, can the same pistons be used? Is more bore clearance required? Is it harder on rings? Any requirement for different fuel oil mix? etc.
I appreciate you taking the time to answer my questions so far.
HYPERSAWS
West coast cutter
1:59 PM
Oregon
Is U.S chrome where you would send it to be bored and replated?
Red97
4:59 PM
MI
Don't really have all the answers...
But have 1 liner cylinder that runs, only a couple tanks use so far.
Used the same piston/caber ring
I try and hit .002 clearance on this one. Looks to be pretty close in the ring travel area, more under the intake port from the hone flairing out trying to finish by the band.
Ring life? Idk? Some of the fancy rings may actually be hard on the bore..
I use the same heavy 40:1 ish in everything.
That was who I called, they didnt act super interested, stating how difficult it was to do a blind cylinder. Didn't matter size etc said price is 276$ if we think we can even do it. And may be more if they have to send out to id grind. Imagine he was taking about open transfer cylinders.
Red97
4:59 PM
MI
It's possible to make a sleeve from 6082 t6 alu and have it nicasil plated.
Cast iron keeps the heat in the sleeve and the 6082 gives the heat further tru the cylinder.
I'm sure it is. But I know plating an open bore is at least 150$
So it is rather cost prohibitive, vs sending a jug to us chrome for bore/plate.
Red97
4:59 PM
MI
Transfers roughed in.
Squish .031
As assembled
In 64.5
Tr 124
Ex 100
Trimmed the piston skirts in the lathe, it tried to walk out of the jaws. I'll get a new one, but a big bevel and run this for the time being.
No free port, and intake at 77 now.
traffic903
6:59 AM
Australia
Thanks for that. Much appreciated.
