Terry Syd
- 5:42 AM
- Jan 18, 2016
- Comboyne, NSW Australia
Is that a picture of the 'someone' or the actual cylinder/piston?
I have seen that type of mod on saws. Normally not firewood saws. The pictures I have are not my work so without permission I prefer not to share terry.Is that a picture of the 'someone' or the actual cylinder/piston?
I don't like what I see above the exhaust port
Most chainsaw cylinders don’t have enough real estateI understand David, no problem on sharing the pictures. As far as the mod, it would be interesting to see how some guys have done it.
It appears to me that not only would it be easier on the rings, but with less grinding on the jug the finger ports could be deeper without compromising the strength of the jug.
I always try opening the primaries first. 3 or 4° later, about the time the primary charge reaches the intake wall, the secondaries open and roll the leading edge of the charge up into a loop.Dolmar 7910...
Talk to me about staggering the transfer ports vs not. I've had suggestions both directions. Im a rookie but I wrapped my head around the porting theory a little bit.
I figured the stagger would continue to direct the charge up into the squish/combustion chamber better than having them flat.
But I'm also considering the timing and the charge going out the other side...
That's what I try for anyway...
This right here is why the quads are so much easier to get to run than the duals. Scavenge loop is key.I always try opening the primaries first. 3 or 4° later, about the time the primary charge reaches the intake wall, the secondaries open and roll the leading edge of the charge up into a loop.
I've tried them every which way. This way seems to have a bit more torque, possibly at the cost of hp, and possibly not. I think you'd need to run the saw every day of the year to he able to tell much difference. It's the right way in my mind, so I roll with itThats along my chain of thought, but I really don't know.
Gotta hold your tongue just right in the corner of your mouth to picture it and do it on duals, lolOf course there are others that have way more experience that can up on the duals.
